Did I brick my Zooz S2 Zen77 dimmer? Installed it without turning the breaker on. I think when pushing the switch back into the box, the screws came in contact with the switch beside it, perhaps putting 120v somewhere it should not have gone.
No blue light, won’t connect, won’t reset to factory. Voltmeter shows 120v between neutral and line as measured ON THAT SWITCH. When I jump the line and load, the lights turn on, and the dumb 3-way works to turn the lights on and off.
So sure sounds like the switch. Is it that easy (I know I screwed up) to brick the Zooz switches, or any others for that matter?
