Did I complete the HA download right, Nothing seems to work?!
Hello
This is my second attempt at HA. First time I go it down loaded bet then was unable to get in configurator and basiclly froze myself out. So I started all over. NOW I cannot get duckDNS to work or letencrypt and my sambashare is working but the SSL file is empty. I have seen many videos using PUTTY to back door the system but I have realized mine always says the files are not there. So did I not download everything?
My DuckDNS log
INFO: Using main config file /data/workdir/config
  • Account already registered!
    Thu Jan 17 23:09:35 UTC 2019: KO
Processing http://[email protected]
  • Signing domains…
  • Generating private key…
  • Generating signing request…
    end of string encountered while processing type of subject name element #1
    problems making Certificate Request
My letsencrypt log
Saving debug log to /var/log/letsencrypt/letsencrypt.log Plugins selected: Authenticator standalone, Installer None Obtaining a new certificate Performing the following challenges: http-01 challenge for example.com http-01 challenge for mqtt.example.com http-01 challenge for hass.example.com Waiting for verification… Cleaning up challenges Failed authorization procedure. mqtt.example.com (http-01): urn:acme:error:dns :: DNS problem: NXDOMAIN looking up A for mqtt.example.com, example.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://example.com/.well-known/acme-challenge/n3KU50tHKv6GrajN0MANhT3D9HxXfrWu1PH4ZbkLmss: "<!doctype html>\n<html>\n<head>\n <title>Example Domain</title>\n\n <meta charset=“utf-8” />\n <meta http-equiv=“Content-type”, hass.example.com (http-01): urn:acme:error:dns :: DNS problem: NXDOMAIN looking up A for hass.example.com IMPORTANT NOTES: - The following errors were reported by the server: Domain: example.com Type: unauthorized Detail: Invalid response from http://example.com/.well-known/acme-challenge/n3KU50tHKv6GrajN0MANhT3D9HxXfrWu1PH4ZbkLmss: "<!doctype html>\n<html>\n<head>\n <title>Example Domain</title>\n\n <meta charset=“utf-8” />\n <meta http-equiv=“Content-type” To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address. - The following errors were reported by the server: Domain: mqtt.example.com Type: None Detail: DNS problem: NXDOMAIN looking up A for mqtt.example.com Domain: hass.example.com Type: None Detail: DNS problem: NXDOMAIN looking up A for hass.example.com
I am really having a hard time with following the Youtube step by step and I am new to this so the text documents on line have not helped.
Home assistant is not documented on youtube, it is documented on the web.
Nickrout
Are you trying to tell me that the tutorials on youtube are wrong? or that you dont approve of them?
As a starter for 10…
You have put an @ sign in your url. I suspect with a reasonable degree of certainty that it should be a dot.
They tend to be out of date very quickly, but no one deletes the it if date ones. Also they are not “official”.
I corrected that and it still comes up with the same element #1 problem.
I was hoping that was it.
I am seeing that you are right about the youtube videos.
So after looking around at all of the addons I find that everyone of them has an issue in the log. Can it be that I set everyone of them up wrong? or is one of them wrong which is messing up the others? or for some reason was the download wrong and I am missing files?
Current addons
DuckDNS, Samba share, SSH server, Configurator, Lets Engcrypt
