Did I configure my energy dashboard correctly?
Hello everybody,
I’m wondering if somebody could tell me if I configured my energy dashboard correctly in the way that I did it. Perhaps I can make it easier or perhaps there are still some mistakes.
I’m reading my p1 meter using an DIY P1 meter. https://github.com/daniel-jong/esp8266_p1meter. I’m receiving values using MQTT. My elektricity meter has 2 tarifs, low and high, it’s reading the total of both tarifs seperate.
- platform: mqtt
  name: P1 Consumption Low Tariff
  unit_of_measurement: 'kWh'
  state_topic: "sensors/power/p1meter/consumption_low_tarif"
  value_template: "{{ value|float / 1000 }}"
- platform: mqtt
  name: P1 Consumption High Tariff
  state_topic: "sensors/power/p1meter/consumption_high_tarif"
- platform: mqtt
  name: P1 Return Delivery High Tariff
  state_topic: "sensors/power/p1meter/returndelivery_high_tarif"
- platform: mqtt
  name: P1 Return Delivery Low Tariff
  state_topic: "sensors/power/p1meter/returndelivery_low_tarif"
To combine these tariffs i created a template sensor:
  sensors:
  #Totaal verbruik, hoog en laag.
    verbruik_totaal:
      friendly_name: Verbruik totaal
      unit_of_measurement: kWh
      value_template: "{{ states('sensor.p1_consumtie_hoog_tarief')|float + states('sensor.p1_consumtie_laag_tarief')|float }}"
  #Totaal teruglevering
    teruglevering_totaal:
      friendly_name: Teruglevering totaal
      value_template: "{{ states('sensor.p1_teruglevering_laag_tarief')|float + states('sensor.p1_teruglevering_hoog_tarief')|float }}"
This gives me 1 sensor with the total electricity usage of my house, tariff low and high combined and 1 sensor with the combine electricity which I return to the grid.
To log this usage, I created an utility_meter which resets daily:
dagelijks_stroomverbruik_totaal:
  source: sensor.verbruik_totaal
  cycle: daily
dagelijks_teruglevering_totaal:
  source: sensor.teruglevering_totaal
  cycle: daily
I’m using the utility_meter in my energy dashboard as grid consumption. I did the same with my grid return from my solar panels. I also added the lifetime energy from my Solaredge inverter integration to the Solar Panels option in the energy dashboard.
I would love to hear if this is the correct way to set this up.
Thank you
It looks like everything is working fine so far. Maybe somebody can use this information to correctly build their own dashboard.
