DieselHeater
Does anybody have a working ESPHOME configuration for a chinese dieselheater using Rf433?
I found some code on github ,but not yaml
So i tried to convert it but i dont speak yaml …
Can somebody correct it?
There are errors in the sensor section
esphome:
  friendly_name: DieselHeater
  includes:
    - diesel_heater_rf_component.h
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "6QzAt5C58NERK/M/mLUMJKtBCInp12VSfsTy+EgsjtU="
ota:
  - platform: esphome
    password: "be76ca0d1a3c0a67c7b17c84a5fe2e56"
#Network
wifi:
  ssid: BRAINTUNING
  password: xxxxxxx
  manual_ip:
    static_ip: 192.168.1.170
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  ap:
    ssid: "Dieselheater Fallback Hotspot"
    password: "xxxxx"
captive_portal:
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO23
  miso_pin: GPIO19
custom_component:
  - lambda: |-
      auto heater = new DieselHeaterRFComponent();
      App.register_component(heater);
      return {heater->get_temperature_sensor(), heater->get_power_sensor()};
  - platform: custom
    lambda: |-
      return {DieselHeaterRFComponent::temperature_sensor};
    sensors:
      temperature:
        name: "Heater Ambient Temperature"
        unit_of_measurement: "°C"
      voltage:
        unit_of_measurement: "V"
# Example of a switch to send a command
switch:
    turn_on_action:
      - lambda: |-
          DieselHeaterRFComponent::send_wakeup();
