DieseRC 4-Channel eWeLink Relay — Home Assistant Integration
Created using Claude Code
Control your DieseRC 4-Channel WiFi Smart Switch (DC 5V–36V passive dry-contact relay) from Home Assistant using the SonoffLAN custom integration via HACS.
No firmware flashing required. Works with the original eWeLink firmware over your local network (LAN) and/or the eWeLink cloud.
Device Details
Property Value
Brand DieseRC
Channels 4 independent dry-contact relays
Input voltage DC 5V / 12V / 24V / 36V
App eWeLink
Protocol eWeLink (CoolKit)
Likely UIID 7 (4ch strip) or 84 (4ch)
Modes Inching (momentary) / Self-locking (toggle)
Prerequisites
  • Home Assistant 2023.6 or newer
  • HACS installed
  • An active eWeLink account with the DieseRC device already paired
  • The device and HA on the same 2.4 GHz Wi-Fi network
Step 1 — Install SonoffLAN via HACS
  1. Open Home Assistant → HACSIntegrations
  2. Click ⋮ → Custom repositories
  3. Add AlexxIT/SonoffLAN with category Integration (skip if it already appears in search)
  4. Search for Sonoff and click Download
  5. Restart Home Assistant
Or click the badge below if your HA instance is reachable:
Step 2 — Add the Integration
  1. Go to Settings → Devices & Services → Add Integration
  2. Search for Sonoff
  3. Enter your eWeLink email and password
  4. Set Mode to auto (uses LAN when available, falls back to cloud)
  5. Click Submit
HA will pull your device list from eWeLink and save it locally. Your 4-channel relay should appear as four switch entities.
Step 3 — Configure configuration.yaml
Add the following to your configuration.yaml to label each channel correctly and ensure proper device class assignment.
sonoff: devices: # Replace YOUR_DEVICE_ID with the 10-character ID shown in the eWeLink app # (tap the device → top-right ⋮ → Device Info → Device ID) YOUR_DEVICE_ID: name: "DieseRC 4CH Relay" device_class: - switch: 1 # Channel 1 — rename as needed (e.g. "Relay 1") - switch: 2 # Channel 2 - switch: 3 # Channel 3 - switch: 4 # Channel 4
Rename channels to match your load
sonoff: devices: YOUR_DEVICE_ID: name: "DieseRC 4CH Relay" device_class: - switch: 1 # e.g. Gate - switch: 2 # e.g. Garden Lights - switch: 3 # e.g. Pump - switch: 4 # e.g. Spare
After saving, go to Settings → Devices & Services → Sonoff and rename each entity from the UI to whatever label matches your wiring.
Step 4 — If the Device Is Not Detected (UIID Override)
Some DieseRC units register as an unrecognized UIID. If your relay appears as a single switch or shows incorrect channel count, add the extra override to force the correct protocol:
sonoff: devices: YOUR_DEVICE_ID: name: "DieseRC 4CH Relay" extra: { uiid: 7 } # Try 7 first (4ch strip). If wrong, try 84. device_class: - switch: 1 - switch: 2 - switch: 3 - switch: 4
How to find your actual UIID:
  1. In HA go to Settings → Devices & Services → Sonoff → ⋮ → Download diagnostics
  2. Open the JSON file and look for "uiid" inside your device entry
  3. Use that value in the extra override if needed
Step 5 — Inching (Momentary) Mode
If you need a channel to pulse briefly (e.g. a gate trigger), configure inching mode in the eWeLink app per channel, then automate it in HA:
Example automation: pulse Channel 1 for gate release automation: - alias: "Gate pulse" trigger: - platform: state entity_id: input_button.gate_trigger action: - service: switch.turn_on target: entity_id: switch.dieserc_4ch_relay_1 - delay: "00:00:01" - service: switch.turn_off target: entity_id: switch.dieserc_4ch_relay_1
Or use the inching duration set in the eWeLink app — HA just sends turn_on and the device handles the auto-off timing itself.
No, I cannot provide support or modifications.
Yes, you can fork my repo and make all the changes you like.
