Dietpi and home assistant. Custom files and where to put them?
Hi all,
Iv’e got some problems to use custom pictures/sounds. I have installed hass on a RBPi3 with DietPi. No problem, works as a charm. But I can’t get the correct path to the folder where I want to store my pictures and sounds.
Iv’e red about /local/ but it doesn’t work for me.
This is the path (copied from the ssh terminal):
root@osmc_hassio:/home/homeassistant/.homeassistant/media/images/image.jpg
This is the copied path from my laptop (SMB):
smb://osmc_hassio/dietpi/homeassistant/media/images/image.jpg
They link to the same folder, bu I don’t know which path to use in hass
Ok, solved it! I had no folder called ‘www’. Once I created it, ‘/local/ path’ works!
Can be closed now!
