I was using the raspberrypi4-64-homeassistant image on my raspberrypi 4. But it has got no update for a month.
Is it safe to switch to the homeassistant/home-assistant image? And what’s the differences between them?
I’m guessing you didn’t read the breaking changes for 2023.7:
If you use the Home Assistant Container installation method, for example, using Docker, please make sure you are using our official (multi-platform) images.
The correct and preferred image to use for our stable releases is:
ghcr.io/home-assistant/home-assistant:stable…
Yes, and the former allows Docker to pull the right architecture. The other are intermediate images, explained in the breaking changes above.
Got it. Thank you!
