Different automation depends on what NFC reader used
I need a bit of help or an idea, let me explain the scenario. I´m using a nuki 3 pro linked to the home assistant. I currently use a nfc reader to arm and disarm the alarm, I´m thinking to add a second reader outside the door.What I want is to use the same tags, but depending on what reader its been scanned to do different actions.
Say when a tag its been scanned to reader A ( outside the door) to unlock the door if its locked and lock the door if its unlocked but don’t change the alarm. Then after entering the house scan the same tag to a different reader B ( inside the house) and this time to disarm the alarm it its armed or to arm the alarm if its disarm.
Thank you.
