Different configuration.yaml
Hi everybody,
I’ve just installed HA with the all in one installer on my Raspy pi3 but I have a problem…
All it’s work but when I try to implement a new sensor or other in the configuration.yaml I have an error.
I have the HA installed on my Mac also and it works perfectly, even when I add sensor or try different configuration.
Now, I put the Mac configuration.yaml into the raspberry…but nothing, error occurred, seems the sintax.
Which is the difference between 2 files??
Thanks…
Have you tried to just copy and paste the text from one file to the other file, that may solve your problem. I have no answer to your question though.
Yes… I’ve tried… Always error, I don’t know why…
Would you be so kind as to share the errors so we can see what is wrong?
Tonight when i coma back to home i will post the config and the error with the checker tool,
Thank you
Ok…solved, the nano editor put me an hidden TAB…damned!!!
Thanks…
