Hello, I am trying to control my water boiler through an automation.
The water boiler accepts a phone line, so I have set up a FreePBX system with an ATA. Then, homeassistant runs a shell_command to copy a call file to the /var/spool/asterisk/outgoing FreePBX dir, that causes FreePBX to call the boiler and send the DTMF tones for it to run for 30 minutes.
I also have a shell_command to turn the boiler off with the same method.
My problem is that the on state of the boiler only lasts for 30 minutes. So, I wrote up an automation to run the shell_command every 32 minutes so that it keeps the boiler running continuously. The automation gets triggered by an input_boolean.
Now, I want the input_boolean to have a dual action. If I turn it on, I want the automation to run as mentioned above, but if I turn it off, I want it to issue the boiler off shell_command. How can I do this?
Here is my configuration.yaml:
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
shell_command:
boiler_heat_on: cp /asterisk/turn_boiler_on.call /asteriskout/.
boiler_heat_off: cp /asterisk/turn_boiler_off.call /asteriskout/.
# Example configuration.yaml entry
input_button:
boiler_heat_off:
name: Boiler heat OFF
boiler_heat_on:
name: Boiler heat ON
automation boiler off:
- platform: state
entity_id: input_button.boiler_heat_off
- service: shell_command.boiler_heat_off
automation boiler on:
initial_state: false
- platform: state
entity_id: input_button.boiler_heat_on
- service: shell_command.boiler_heat_on
automation keep boiler on:
alias: "Run Boiler Until Off"
- platform: state
entity_id: input_boolean.keep_boiler_on
condition:
- condition: state
state: "on"
repeat:
sequence:
- delay:
minutes: 32
until:
- condition: state
state: "off"
input_boolean:
keep_boiler_on:
name: Keep Boiler On
initial: false
Relevant sections are: automation keep boiler on AND input_boolean
