I dumped the following in the templating editor (as well as defined the sensor from the text within
ac_last_changed:
friendly_name: 'AC Last Changed From Present'
unit_of_measurement: 'seconds'
value_template: >-
{% set CONTROL = 'sensor.be469zp_connect_smart_deadbolt_access_control' %}
{% set CONTROLlc = states.sensor[CONTROL.split('.')[-1]].last_changed %}
{{ as_timestamp(now()) - as_timestamp(CONTROLlc) }}
AC Sensor {{ states.sensor.ac_last_changed.state }}
Here is the template output:
ac_last_changed:
value_template: >-
231.27665901184082
AC Sensor 1.457772970199585
Everytime I modify the template code, I see the value_template “update” with the difference between “now()” and the last changed time for sensor.be469zp_connect_smart_deadbolt_access_control
. This is the expected and desired behavior. However the value for ac_last_changed
is not changing. What am I doing wrong?
What I’m attempting to do is create a sensor that returns the number of seconds from the current time that the entity was last changed. I have several other things I want to use this value, such as making sure the last_changed property changed within 5 seconds in one automation and 30 in another.
Pinging @freshcoast and @arsaboo as they commented on a similar issue
