My goal is to display text in Dashboard how many lights are on. That is quite easy, but to make it little bit harder I want to count lights used in groups as one light
My idea was to add to grouped lights new attribute - grouped: “on” and then count all the lights that are on minus all the lights that are grouped. If you have more elegant solutions, I am opened to suggestions.
I have created sensor to do that, but found out it was working, but rather slowly. It wasn’t instantly changed but it took some time to display new value (20 seconds+).
I have divided the sensor into 2:
- counting number of lights that are on - easy + instant change of the value
sensors:
lights_count_b:
value_template: >-
{% set count = states.light
| selectattr('state', 'eq', 'on')
| map(attribute='entity_id')
| list
| count %}
{{ count }}
- counting number of lights that are on, but also having attribute grouped = “on” - this takes 20 seconds + to refresh. I don’t know why.
sensors:
lights_count_a:
value_template: >-
| selectattr('domain', 'eq', 'light')
| selectattr('attributes.grouped', 'eq', 'on')
| list
| count %}
{{ count }}
Can you help me figure this out? Or if you have better solution, please let me know.
