Hi
I just updated my HA from 0.63.3 to 0.64. I had to relogin to HA cloud but had lost password ! I tried the reset feature in web interface but went into errors. Nevertheless I still received an email with the code to reset password which I did.
Now when I try to login I get an unknown error and logs have these:
Log Details (ERROR)
Mon Feb 26 2018 08:10:28 GMT+0100 (CET)
Error handling request
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web_protocol.py", line 416, in start
resp = yield from self._request_handler(request)
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web.py", line 325, in _handle
resp = yield from handler(request)
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web_middlewares.py", line 93, in impl
return (yield from handler(request))
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/static.py", line 70, in staticresource_middleware
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/real_ip.py", line 28, in real_ip_middleware
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/ban.py", line 70, in ban_middleware
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/auth.py", line 29, in auth_middleware
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/__init__.py", line 409, in handle
result = yield from result
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/cloud/http_api.py", line 50, in error_handler
result = yield from handler(view, request, *args, **kwargs)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/data_validator.py", line 48, in wrapper
result = yield from method(view, request, *args, **kwargs)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/cloud/http_api.py", line 83, in post
data['password'])
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/cloud/auth_api.py", line 124, in login
cognito = _authenticate(cloud, email, password)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/cloud/auth_api.py", line 154, in _authenticate
assert not cloud.is_logged_in, 'Cannot login if already logged in.'
AssertionError: Cannot login if already logged in.
Interesting to see that logs indicate I’m already logged in but on frontend I appear not ! Then I navigated into web interface to go to main tab and back at configuration one and now I appear correctly logged !!
Vincèn
