Difficulty getting aarlo Lovelace card working
I’ve installed the “Arlo Camera Support” and “Lovelace Haas Aarlo” plugins from the HACS store.
The “Arlo Camera Support” is working and I see the camera entities.
I’m now trying to get the “Lovelace Haas Aarlo” card working. I’ve added the following to my RAW UI Configuration:
resources:
  - type: module
    url: /community_plugin/lovelace-hass-aarlo/haas-aarlo.js
I’ve then added the card to my UI as follows (per the documentation here: https://github.com/twrecked/lovelace-hass-aarlo
      - entity: camera.aarlo_front_yard
        image_click: play
        show:
          - motion
          - sound
          - snapshot
          - battery_level
          - signal_strength
          - captured_today
          - image_date
        top_date: false
        top_status: false
        top_title: false
        type: 'custom:aarlo-glance'
But, the UI shows the following error:
I’m trying to find the haas-aarlo.js file from somewhere.
I’m on hasbian so I need to find a place to donwload the .js file - could you please help me find a source? Hopefully I can help you with your card when I install the js file.
@pickerin Did you ever figure this out? I’ve used HACS to install aarlo and lovelace-hass-arlo card. As part of the lovelace-hass-arlo install it has a GUI for adding the resource (barks if you don’t do it) and it adds the following:
which is a path that doesn’t seem to exist as the install itself put the js file in /www/community/lovelace-hass-aarlo/
I’ve tried creating a resource for the real location as well, and I just get the custom element doesn’t exist error
I just got it working now…
My lovelace config is…
entity: camera.aarlo_veggie_patch
type: ‘custom:aarlo-glance’
show:
  • motion
  • sound
  • snapshot
  • battery_level
  • signal_strength
  • captured_today
  • image_date
    top_date: false
    top_status: false
    top_title: false
I have hass-aarlo.js in two paths - probably only one is required!
config\www\custom_ui
and
config\www\community\lovelace-hass-aarlo
I have these two components installed using HACS
Integrations - Arlo Camera Support
Plugin - Lovelace Hass Aarlo
and I believe I added resources to Lovelace as well (using HACS UI)
Hope that helps.
-Steve
Thanks, do you have something in configuration.yaml or are you using the lovelace resources GUI?
I have this
aarlo:
  username: !secret arlo_username
  password: !secret arlo_password
  refresh_devices_every: 2
  stream_timeout: 120
alarm_control_panel:
  - platform: aarlo
    home_mode_name: Disarmed
    away_mode_name: Armed
    night_mode_name: Armed Silent
    trigger_time: 30
    alarm_volume: 8
  - platform: aarlo
    monitored_conditions:
      - total_cameras
      - last_capture
      - recent_activity
      - captured_today
      - battery_level
      - signal_strength
in configuration.yaml - hope that helps!
Yes, I did get it working…
First, “hacsfiles” is a generic path element that will normally map to /www/community as you’ve discovered. It was a recent change to HACS and all components should be moved to using /hacsfiles in all configurations, so they can essentially define it once and have all components use the abstracted one, so don’t sweat that, right now it will work with either.
Here is the configuration for my card. This is defined WITHIN THE LOVELACE UI, not in a configuration file:
image_click: play
show:
  - motion
  - sound
  - snapshot
  - battery_level
  - signal_strength
  - captured_today
  - image_date
top_date: false
top_status: false
top_title: false
The component is installed in: /www/community/lovelace-hass-aarlo
The contents of that folder are: hass-aarlo.js and hass-aarlo.js.gz
In my Lovelace UI Resources page (found under Configuration > Lovelace Dashboards > Resources tab), I have:
/hacsfiles/lovelace-hass-aarlo/hass-aarlo.js, as a JavaScript Module
Thank you for explaining it all like that. It is working for me now!
I’ve been having the same problem. Where do I find the resources tab when I navigate to configuration/Lovelace dashboards? I don’t have resources at the top.
I think what breaks my cards is when I try to load the dashboard on the iOS app. I’m using it on my home network but I also have nabu casa and have the iOS app set to use the nabu casa url.
Should look like this (Configuration > Lovelace Dashboards), you have two “tabs” at the top: Dashboards and Resources:
Hmm, I definitely don’t have that. Missing the resources tab.
You have to have enabled “Advanced Mode” in your user profile:
Gotcha :+1: thank you
I’m at a loss. I have lovelass-hass-aarlo installed from HACS. I have the right resource in my Loveless UI as /hacsfiles/lovelace-hass-aarlo/hass-arlo.js I can see the files in /www/community/lovelace-hass-arlo and I have all the sesnors configured in configuration.yaml but I am still getting the Custom element doesn't exist: aarlo-glance. error when I try to use a manual card with the following config:
entity: camera.aarlo_backyard_camera
show:
  - motion
  - sound
  - snapshot
  - battery_level
  - signal_strength
  - captured_today
  - image_date
top_title: false
top_status: false
top_date: false
image_click: play
light: light.back_porch
It should be “aarlo” not “arlo” in your Lovelace Dashboard Resources:
“/hacsfiles/lovelace-hass-aarlo/hass-aarlo.js”
That was a typo in my post. It is hass-aarlo.js in my hacsfiles path
Strange. It seems to be working now.
A quick update.
If you need live stream on click, add play_direct: true to your lovelace hacs aarlo config
With the HACS installing the lovelace card files at /config/www/community/lovelace-hass-aarlo/hass-aarlo.js,
To get it to work, I ended up using:
Lovelace Resources URL: /local/community/lovelace-hass-aarlo/hass-aarlo.js
I have aarlo installed and running by following these instructions:
Manually
Copy the aarlo directory into your /config/custom_components directory.
I can see this
How do I install lovelace-hass-aarlo if I am on docker?
