Difficulty getting SLZB-MR1, iphone and Eve accessory to add devices
So I’m not new to HA but definitely to the entire Matter/Thread Border Router thing. What I’m running is a virtualized HAOS installation within proxmox, and SLZB-MR1 for my thread border router and and Eve Smart Outlet.
iOS version 18.6.2
In terms of my SLZB-MR1, here is my network settings.
I’m running SLZB OS 2.9.8 and the CC2652P7 is flashed with 20240727.
In terms of Home assistant, I’m running the following:
  • Installation method Home Assistant OS
  • Core 2025.9.4
  • Supervisor 2025.09.0
  • Operating System 16.2
  • Frontend 20250903.5
I have the Python Matter Server installed:
  • Python Matter Server
    FabricId: 2
    Compressed FabricId: 3297496690525811000
    SDK Wheels Version:2025.7.0
    Schema Version: 11
    Node count: 0
I have Matter, Thread and Open Thread Border Router Integrations.
I also have the Matter Server Add On and it’s configured as follows:
The Thread Integration shows the following:
So that’s all the background.
So to attempt to add a device – I will strictly use the iphone or iOS.
Within Chrome browser on the phone, I will login to my home assistant instance and go to Settings->Devices and services->Thread. I’ll click on the the Configure Gear and I’m shown the following:
I’ll simply just press on the Icon Home Assistant Open Thread Border. That’s it. I’m not sure what to do other than just click on the “button” which doesn’t look like a button.
Anyway I have an Eve Energy Outlet. I’ve tried adding the device which is powered on with two green lights to both the Eve App and also tried adding to Apple Home Kit. I’ll get:
And this process just sits and spins for quite a long time, then finally I get:
I’m not too sure what to do at this point. It seems like I have a valid thread border router.
**So I reset the smart outlet by holding down right button for 5 seconds (I believe this is factory reset.) I rebooted home assistant as well.
For the logs specifically of the OpenThreadBorder Router I have the following:
System: Home Assistant OS 16.2 (amd64 / qemux86-64)
Home Assistant Core: 2025.9.4
Home Assistant Supervisor: 2025.09.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service universal-silabs-flasher: starting
[22:25:46] INFO: Flashing firmware is disabled
s6-rc: info: service universal-silabs-flasher successfully started
s6-rc: info: service otbr-agent: starting
[22:25:47] INFO: Setup OTBR firewall...
[22:25:47] INFO: Starting otbr-agent...
[NOTE]-AGENT---: Running 0.3.0-b067e5ac-dirty
[NOTE]-AGENT---: Thread version: 1.3.0
[NOTE]-AGENT---: Thread interface: wpan0
[NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///tmp/ttyOTBR?uart-baudrate=460800&uart-init-deassert
[NOTE]-AGENT---: Radio URL: trel://enp6s18
[NOTE]-ILS-----: Infra link selected: enp6s18
tiocmbic: Inappropriate ioctl for device
49d.17:03:16.378 [C] P-SpinelDrive-: Software reset co-processor successfully
00:00:00.170 [N] RoutingManager: BR ULA prefix: fd49:343:c5ce::/48 (loaded)
00:00:00.170 [N] RoutingManager: Local on-link prefix: fd7c:4bf6:a4aa:4a2::/64
s6-rc: info: service otbr-agent successfully started
s6-rc: info: service otbr-agent-configure: starting
00:00:00.207 [N] Mle-----------: Role disabled -> detached
00:00:00.215 [N] P-Netif-------: Changing interface state to up.
00:00:00.229 [W] P-Netif-------: Failed to process request#2: No such process
00:00:00.230 [W] P-Netif-------: Failed to process request#6: No such process
Done
s6-rc: info: service otbr-agent-configure successfully started
s6-rc: info: service otbr-agent-rest-discovery: starting
[22:25:48] INFO: Successfully sent discovery information to Home Assistant.
s6-rc: info: service otbr-agent-rest-discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
00:00:27.359 [N] Mle-----------: RLOC16 8800 -> fffe
00:00:27.946 [N] Mle-----------: Attach attempt 1, AnyPartition reattaching with Active Dataset
00:00:34.446 [N] RouterTable---: Allocate router id 34
00:00:34.446 [N] Mle-----------: RLOC16 fffe -> 8800
00:00:34.454 [N] Mle-----------: Role detached -> leader
00:00:34.456 [N] Mle-----------: Partition ID 0x55112ae7
Default: mDNSPlatformSendUDP got error 99 (Cannot assign requested address) sending packet to ff02::fb on interface fe80::1037:8bff:fe47:82b2/vethff9b6e0/13
[NOTE]-BBA-----: BackboneAgent: Backbone Router becomes Primary!
Default: mDNSPlatformSendUDP got error 99 (Cannot assign requested address) sending packet to ff02::fb on interface fe80::d4f5:c2ff:fecf:bce3/vethb396f5e/14
00:00:37.081 [W] DuaManager----: Failed to perform next registration: NotFound
Anyway – still get accessory not found.
Matter – thought it was plug and play. Doesn’t seem to be the case.
** I did end installing home assistant app on IOS and was able to get button on Thread integration screen about send credentials to phone. I clicked on this and received green check.
Accessory during pairing process still not found however.
If you look at the the docs you’ll see the preferred network should have a border router with a little key-in-a-box icon beside it.
However the docs currently don’t explain what this icon means, or how to make it appear, so don’t feel bad for missing it.
It means that the router’s credentials can be shared with iOS (or Android). Without the key-in-a-box icon, the app’s “Send credentials the phone” button does nothing, even though it is inexplicably visible and still shows a green check when pressed.
You can make the icon appear by clicking the three-dot menu beside the router name and selecting “use for Android/iOS credentials”. If you don’t see this option in the menu, it means you haven’t setup the OTBR integration, which is separate from the Thread integration and required for that menu item to appear (the docs don’t explain this anywhere, either).
Once you have the key-in-a-box, try “Send credentials to phone” again and then go to Settings → Companion App → Debugging → Thread and make sure your ha-thread-e5e7 network is the only entry in the list of iCloud keychain.
