Difficulty to start the VB
I have a error when I start de VB
end of log
00:00:29.004428 E1000#0: Received frames : 0
00:00:29.004433 E1000#0: Transmitted frames: 0
00:00:29.004439 E1000#0: TX frames up to 1514: 0
00:00:29.004444 E1000#0: TX frames up to 2962: 0
00:00:29.004449 E1000#0: TX frames up to 4410: 0
00:00:29.004454 E1000#0: TX frames up to 5858: 0
00:00:29.004459 E1000#0: TX frames up to 7306: 0
00:00:29.004464 E1000#0: TX frames up to 8754: 0
00:00:29.004469 E1000#0: TX frames up to 16384: 0
00:00:29.004474 E1000#0: TX frames up to 32768: 0
00:00:29.004479 E1000#0: Larger TX frames : 0
00:00:29.004484 E1000#0: Max TX Delay : 0
00:00:29.040727 GIM: KVM: Resetting MSRs
00:00:29.044475 Changing the VM state from ‘DESTROYING’ to ‘TERMINATED’
00:00:29.051615 Console: Machine state changed to ‘PoweredOff’
00:00:29.643923 GUI: Passing request to close Runtime UI from machine-logic to UI session.
00:00:29.830103 GUI: UIMachineViewNormal::resendSizeHint: Restoring guest size-hint for screen 0 to 800x600
00:00:29.830181 ERROR [COM]: aRC=E_ACCESSDENIED (0x80070005) aIID={4680b2de-8690-11e9-b83d-5719e53cf1de} aComponent={DisplayWrap} aText={The console is not powered up}, preserve=false aResultDetail=0
00:00:29.830282 GUI: Aborting startup due to invalid machine state detected: 1
Hi, were u able to fix it. I tried on ubuntu with Virtual Box version 6.1.16 r140961 (Qt5.12.8).
Please let me know if is solved
I had turned on the android emulator at the same time which had a conflict with hyper x virtualization. I suggest you make sure hyperx virtualization is enabled from your motherboard.
