I’m new to automation. Surprised that no one has thought to control this device yet as the IT community likes to use them to restart modems, switches, pc’s etc remotely. It’s the basic, “Have you turned it off and on again?” except you can do it yourself via the web.
There doesn’t need to be specific support for this device as it can already be controlled by GET API calls, as stated on the FAQ you linked to:
To turn Outlet 2 ON:
http://192.168.0.100/outlet?2=ON
To turn Outlet 5 OFF:
http://192.168.0.100/outlet?5=OFF
To cycle Outlet 7:
http://92.168.0.100/outlet?7=CCL
To start a script on line 90 at the default IP after authenticating admin with password 1234:
http://admin:[email protected]/script?run090
I’m not sure you need to pass the admin and password on every call or just when running scripts on the device, but I added it in there for all calls just in case. So you should just create a command_line switch for each of the outlets, and maybe even one to toggle all the outlets:
You can even use the command for cycling an outlet rather than explicitly turning it on or off, by creating a shell_command and using it in a script and then placing the script directly within a group, then you can just hit the ACTIVATE button shown to power cycle the outlet:
With the above, you would have a group called “Actions” (just an example, you can call it anything you like) that has 3 items in it… The first being a switch to turn on/off all outlets, the second being a switch to turn on/off outlet 1, and the third will show as an ACTIVATE button to power cycle outlet 1
Thank you for this! I was also looking for the same kind of control options.
Is it possible to set a script that would turn on only a select number of outlets? Say I wanted to be able to turn on and off 1, 2, and 3 on at the same time, would that just be:
