Digital Pressure Sensor QDW90A ESP Home
I am using the ESP32-S3-ETH-8DI-8RO and wanted to add a pressure sensor to the RS485 port on it.
Sensor QDW90A (with or without screen)
I had trouble finding the right settings and wanted to share them with you now that everything is working correctly.
It is important that you connect the GND of the RS port to a G on the internal pin block.
# RS485 / MODBUS - DRUKSENSOR
uart:
  tx_pin: GPIO17
  rx_pin: GPIO18
  baud_rate: 9600
  parity: NONE
  stop_bits: 1
modbus:
  uart_id: modbus_uart
modbus_controller:
  - id: pressure_controller
    address: 1
    modbus_id: modbus1
    update_interval: 60s
    command_throttle: 50ms
  # SYSTEEMDRUK - RS485 MODBUS
  - platform: modbus_controller
    modbus_controller_id: pressure_controller
    register_type: holding
    address: 4
    value_type: U_WORD
    unit_of_measurement: "bar"
    device_class: pressure
    state_class: measurement
    accuracy_decimals: 3
    filters:
      - multiply: 0.001
      - lambda: |-
          if (x < 0) return 0;
          if (x > 5.5) return 0;
          return x;
Cheers,
Sake Banga
AKA Toendra
