Digitalstrom implementation
The main advantage from digitalstrom is, that it controls light by switch or system bycontrolling power. When zigbee, there has to be power on the bulp at all time. If I use the switch and thus cut power, zigbee light will remain dark…
That’s totally right. However I don’t really get the advantage.
In case of digitalstrom, it cuts power from the light bulb but keeps feeding the terminal.
So where’s the difference if the micro computer doing all the logic is still powered. To me i t doesn’t matter if that one’s integrated in the light bulb or a separate device. Same idea.
I have just stumbled across your post as I’m checking the possibility to integrate dS in HA oder OpenHAB.
The bell, tor opening and an intercom system of the house we are living in is about to be replaced. I suggested to install an smart system to be futur safe.
As the house is located in Switzerland they prefer Swiss vendors, so I came across dS.
It looks like their system would be easy to install and to be allowed to be controlled by other systems.
Due to your summary I may doubt second. Is there any system you recommend instead?
thx
Digitalstrom is controllable by other systems. It just has many issues doing so.
I’m currently in the process of replacing all my Digitalstrom installation with Shelly clamps flashed to ESPHome.
They’re not Swiss made but the company behind it is at least from Europe.
Also Digitalstrom is not really easy to install as it needs components built right into the switchbox. Shelly is running on WiFi so a stable WiFi like Unifi is recommended.
thx for the quick answer.
Unfortunately Shelly does not offer any intercom solutions.
The idea is to have dS intercom to get easy approval from the others living in the house.
I don’t know if it the current intercom is connected to the switchbox. Let’s see and hope the best. In case that is the case, it can use the current wiring, so no extra have to be pulled.
I hope that it can be easily integrated into HA then. I haven’t found any alternative yet.
Well. Feel free to invest in an extremely expensive, closed source, closed infrastructure system. I wouldn’t do it again.
I mean the best thing about HomeAssistant is that it can orchestrate systems from different manufacturers.
What exactly is the use case with the intercom?
One common front-door for seven flats
But what do you want to integrate?
Only that it rings or something more feature complete like opening the door, turning on the light in the hallways, etc.?
I don’t see a reason why you’d want to use Digitalstrom for that. Use a specialized system, maybe even an intercom that is already supported. That’s the magic of HomeAssistant - connect different systems.
all that I need is a smart system for the front door of the house and the doors for each individual flat.
I want to integrate into my HA (what is for my flat only), I don’t think that the other residents that much in home automation.
One flat using smart lights and sockets but as far as I know they use a proprietary system but don’t know the details yet.
I will us another system for other devices in my flat.
The installation has to be done by an qualified person as I don’t want to be responsible for the proper function of the front-door bell system (I don’t have the time to do so and insurance is anther topic to regard).
dS just told me that they don’t have their own system, the would use e.g. DoorBird, so even better, as it allows to use other vendors.
Unfortunately, DB is not that easy to install Doorbird, is it any good?
Then there is no need for DS at all if they don’t even provide such functionality.
Think of all the overhead of DS filters, DS meters, DS server, etc. that don’t actually do anything.
If you want to get consultation about intercom systems, please open a new thread.
I’m officially abandoning the Digitalstrom integration as I got rid of their crazy expensive, not so open system and replaced everything by ESPHome based devices. The integration will still be available but remains unmaintained by me.
If someone wants to take over, let me know.
For those still interested in digitalSTROM with home assistant I created a software to sync digitalSTROM with MQTT.
Hey Gaétan. That’s great news, thanks for your efforts! I installed it and looks like I also get messages in MQTT (checking it with MQTT explorer). However, I’m a bit stuck with the next step, i.e. having actual entities and devices based on it in Home Assistant. Do you have any plans to add support for HA Auto Discovery (https://www.home-assistant.io/docs/mqtt/discovery/)?
Also happy to provide you with any feedback that I can give…
Hey Saimen,
I’m not a Home Assistant user. I use OpenHAB. I stumble upon this topic while searching for an existing implementation of digitalSTROM and MQTT. I just wrote here in case someone was interested.
I will not follow any vendor-specific MQTT implementation. I prefer to stay generic by default.
That being said, my project is open source. So if someone is willing to implement the HA implementation and that we have a clear config property to enable it. I would be ok to integrate it. I know that others are doing it like this (like ZigBee2MQTT)
In the meantime, I’m sure HA is powerful enough to allow you to use the “state” and “command” topics.
I have a question about:
docker run \
  -e DIGITALSTROM_HOST=192.168.1.x \
  -e DIGITALSTROM_USERNAME=dssadmin \
  -e DIGITALSTROM_PASSWORD=XXX \
  -e MQTT_URL=tcp://192.168.1.X:1883 \
  gaetancollaud/digitalstrom-mqtt
is MQTT_URL=tcp://192.168.1.X:1883
  • the ds-server address?
  • or the adress of my HA-server? (on docker)
Hi. This is the address of the system where the MQTT broker is running, not the ds-server…
If the MQTT broker runs on home assistant, then the IP of home assistant.
If the MQTT broker runs separately in a container, then the IP of the container.
Hi, is it possible to explain step by step the Integration in Homeassistant. I Installed mqtt, but no idea about the next steps. Thanks a lot!!!
