Diivo HomGar WG03 Wi-Fi
Hello to all
anybody please can help me to understand why some company didn’t want to integrate the solution with the HUB ?
i’ve buyed the Diivo HomeGar WG03 Wi-Fi with the hope of being able to integrate this on HomeAssistant, but this version didn’t work with Tuya, SmartLife or other and the company didn’t want to develop this integrations;
Is the only solution to take everything and throw it in the garbage?
Hi Matteo,
have same issue, I tried many times to integrate it with Tuya without any chance by my side.
I know that others have been able to integrate using Tuya, but Diivoo was not ours WG03 WiFi, but other models like those with multiple irrigation.
Am still researching somethign for this model, if I find something will post later on.
Ciao
I also searched half of the net for an integration of my WG03 / WT07W water valve, but did not suceed.
Any help would be appreciated.
It’s the last device left to be integrated. And one of the device which would have the biggest benefit from an integration.
Ciao
Jochen
You can use Google Home to connect your HomGar device to HASS.
If you want to go beyond controlling your irrigation via HASS, i.e, you also want to trigger actions in HASS when your irrigation is turned on/off via HomGar app, Google Home/Assistant, or using the hardware buttons on your irrigation device, you need a Google Thread Border Router. More about that at the end of this post; let’s have a look at controlling your irrigation via HASS first:
  1. In your Google Home app (iOS/Android, simply install it in case you don’t have it yet) go to “Devices” - “Add “ - “Works with Google Home” and add “HomGar Smart”, and connect using your HomGar credentials.
  2. In HASS, add the integration “Google Assistant SDK” or, if you also want to capture responses from Google Home/Assistant (which is not necessary if you simply want to control your irrigation), Google Assistant SDK Custom. The necessary steps for setting up this integration are outlined here.
Now you can address the Google Home entities of your HomGar device in HASS; here is an example:
  1. Create a helper toggle (“Devices & services” - “Helpers” - “Toggle”); I’ve named it “zone1”, which leads to the entity being named “input_boolean.zone1”.
  2. Create an automation(“Automations and scenes” - “CREATE AUTOMATION” - “Create new automation").
Use the following trigger (“When”):
trigger: state
entity_id:
  - input_boolean.zone1
And the following action (“Then do”):
if:
  - condition: state
    entity_id: input_boolean.zone1
    state: "off"
then:
  - action: google_assistant_sdk.send_text_command
      command: turn zone 1 off
else:
      command: turn zone 1 on
If you use the custom SDK, use “google_assistant_sdk_custom.send_text_command” in the code above.
In case you prefer to control your irrigation via Python, in my case using AppDaemon (substitute “on” with “off” to turn zone 1 off):
self.call_service(
	service = "google_assistant_sdk/send_text_command",
	command  = "turn zone 1 on”,
or, in case you use the custom integration, substitute line 2 with the following:
	service = "google_assistant_sdk_custom/send_text_command",
As mentioned, using Google Assistant SDK Custom you can additionally capture Google Assistants’ reponses, for example:
	command: is zone 1 open
response_variable: response
action: google_assistant_sdk_custom.send_text_command
The output by Google Home/Assistant can be shown in a text helper:
  value: "{{ response.responses[0].text }}"
  entity_id: input_text.zone1response
action: input_text.set_value
I’ve already mentioned the possibility of having HASS react to your irrigation being turned on/off via Google Home/Assistant, HomGar, or the hardware buttons on your irrigation device. To achieve this, you can use the also otherwise highly commendable add-on Matterbridge.
With Matterbridge up and running, add a helper toggle in Hass and import it in Google Home via Matterbridge. In Google Home then create an automation that switches on/off this “helper” whenever the corresponding valve is turned on/off. In HASS, simply use an automation (or AppDaemon) to react to the changed state of this toggle.
For the Matterbridge to work with Google Home, your Home Assistant needs to be using a Google Thread Border Router, e.g., Google TV Streamer (4K) or Google Nest Wifi Pro.
I am getting interested into it as I have a Diivoo WT-13W (4 channels).
There are mostly 2 generations of Diivoo water timers.
The “old” is the orange one, can be integrated into Tuya then automated in different ways.
The newer in colors green/black are locked into the HomGar app.
I’ll describe mine which is part of the new generation.
The Wifi hub uses 2.4GHz WiFi band - FCC ID: 2A4EP-WG03
The water timer communicates with the hub using 433.92MHz - FCC ID: 2A4EPWT-13W
The device is registered by company Zhuhai Tessan Power Technology Co., Ltd. in China.
I tried to listen to the 433 signals using a flipper zero but the raw signal can’t be replicated, replay just doesn’t turn anything on the outlet. There might be a rolling code but I’m not digging that part as I won’t be able to automate it with my BroadLink.
I don’t have a Google border router and I don’t want to buy one just for that.
Of course, the HomGar API is closed, but I’d like to try to focus on that part as that would be the easiest way to integrate into HA.
I just found this repo made for other devices that use HomGar, I’ll try to dig into it and see if anything can adapt for Diivoo device but I’m not much into that, it might take time.
Anyone have any luck with this? I just got the 4 channel version and Im stuck in the Homgar app.
The google assistant sdk can’t seem to find the device but I can turn other devices on or off. My google nest also can’t access it but assistant on my phone can access it so hopefully I just need to wait a bit for replication but I’d love to find another way.
Thanks for this! There might be hope for this device after all.
Did you have to do anything special to get it to work in the SDK? No matter what I do I can’t control it via the SDK or custom SDK. It can be controlled no problem via my phone’s Google assistant or my nest.
The SDK just says this service hasn’t been setup right.
I’ve enabled personalised results and synced a few times no luck.
When I sync it says it can’t control 4 devices because it can’t verify my voice but if I unlink homgar and try a sync it says the same thing so I don’t think it’s talking about the 4 zones.
Edit: just moved to matterbridge and is worked well. Thanks!
Sorry I may be a little late to the party here. It is also not an ideal solution but this is what I’ve done for years.
I simply connected it to Alexa via their skill which works well.
I then have a virtual switch for each zone in home assistant which is exposed to Alexa. Then it’s just a simple routine in the Alexa to control these.
This allows voice control for each zone and control within home assistant for scheduling etc.
Hi everyone!
I have been working on reverse engineering the protocol over the last year as a hobby project and I have a working prototype. Its pretty alpha but I hope to release it within the next 2 weeks.
How to use it:
There will be a Docker container and later a hacs addon which has to be hosted locally / installed.
Then you need the bridge that came with it. Open it up and flash the gateway software that I wrote which sends commands from the docker container to 433 mhz. There will be a webinterface for simple adoption and muti gateway support if you have a huge area to cover.
What can you do?
Add a valve computer.
Add a offline watering plan that is uploaded to the water computer.
Recieve state updates (valve off/on)
Send valve commands (off / on + how many seconds. 10 seconds to a few hours)
At the moment I only tested this with 4 way valve computer but I think it sould work with all variants that use 433mhz (or as the call it “RFID”).
All is working offline without any cloud connection (only ntp server for time that the watering computer knows when to start if you set a watering schedule)
Stefan
Hi its bin a while but I have very exciting news. TL;DR: I was able to reverse engineer the protocol and put everything into a Homeassistant App/Integration :smiley:
I posted more infos here: Diivoo / Tuya / Smart Home Hose Water Valve - #11 by Stefan_G
Github: GitHub - Technerd-SG/hassio-diivoo2mqtt · GitHub
