Dim/Brighten light on a single button long press
I found in this wonderful forum a script that allows me to dim/brighten a light with hue dimmer v2.
this is the script:
Light UP
alias: Script Name
sequence:
  - service: light.turn_on
      device_id:
        - 8b968b12da6a0a68feed64xxxxxxxxxx
        - b076814025062710d58d64xxxxxxxxxx
      transition: 1
      brightness: >
        {% if not state_attr('light.nume_bec', 'brightness') == None %} {% set
        n = state_attr('light.nume_bec', 'brightness') + 25 %}  {% if n > 255
          255
        {% else %}
          {{ n }}
        {% endif %} {% else %}  25  {% endif %}
mode: single
Light Down
alias: Script Name
sequence:
      device_id:
      transition: 1
      brightness: >
        n = state_attr('light.nume_bec', 'brightness') - 25 %}  {% if n > 255
          255
        {% else %}
          {{ n }}
        {% endif %} {% else %}  0  {% endif %}
mode: single
I also own a Aqara mini switch and I was wondering how I could make a automation to switch between the two scripts by long pressing the aqara button. Basically what I want to do is:
long press = brighten
releases and
long press = dim
Thanks for any help!
Not working :frowning:
You would think there are enough clues but yet your image shows action
Can you now please stop spamming the forum about your dimming not working?
