Same result. Strange because it first worked without the sun part
Ok I see now, you are missing an indent, the first condition only has one space in front of it, add one space in front then try.
Iām not sure what you want me to do.
On line #7 add one space in front of the word condition.
If everything in life was that easy.
Works and green light.
And it is 0:13 so testing time
This was your one time, now everything is up hill, both ways.
Drumroll Please
Uhm. in my UI I only see the closing part and not the opening part in the automation
will reboot. Also GoGogate is not connected
GoGoGate not in UI. Also I mis some parts in my control UI like weather etc.
Were these items there before?
yes. A lot of controls on my UI are missing.
Did you change anything in your configuration.yaml?
Okay GoGoGate back in the UI. But open part in automation is gone. Close part is there
No nothing. Did not open that one.
What version of Homeassistant are you using, and are you using Hassbian or Hassio?
Frontend version: 20190805.0 - latest
Go to the Lovelace UI
REMOVE STATES AS DEFAULT PAGE ON THIS DEVICESystem Health
arch armv7l dev false docker false hassio false os_name Linux python_version 3.7.3rc1 timezone Europe/Amsterdam version 0.97.2 virtualenv true Lovelace
mode storage resources 0 views 3
But. closing part is working. So when I close the gate trough the GoGoGate app the lights dim on the gate and after 1 min the garage lights go off.
Have you taken control of your Lovelace interface, if so I think you will find the missing items in your Unused Enties. You can find this by clicking the 3 dots in the top right corner.
