I think you might be correct, looks like I copied the wrong part of the log, there’s two rough duplicates and the other one doesn’t have the skip: true! Here’s more or less the entire context, check for the same timestamp as above:
2021-04-26 20:32:47 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: False
allowance_value: 0.0
affected_entities: ['light.woonkamer_led_vide']
elevation: 3.43 (8.5, -18)
last elevation: 3.71
new brightness: 189
last brightness: 191
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 193}]
force_turn_on: True
force_turn_off: False
turn_on_entities: []
dim_entities: ['light.woonkamer_led_vide']
turn_off_entities: []
Triggered by: state
to: (elevation: 3.43, azimuth: 288.8)
skip_event: True
affected_entities: []
last elevation: 3.43
new brightness: 189
last brightness: 189
force_turn_on: True
dim_entities: []
Triggered by: event
entity_id: ['light.woonkamer_led_vide']
service_data_length: 3
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': ['light.woonkamer_led_vide'], 'brightness': 189, 'transition': 0}}
2021-04-26 20:34:47 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: False
elevation: 3.16 (8.5, -18)
new brightness: 187
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 189}]
force_turn_on: True
Triggered by: state
to: (elevation: 3.16, azimuth: 289.19)
skip_event: True
last elevation: 3.16
new brightness: 187
last brightness: 187
force_turn_on: True
dim_entities: []
Triggered by: event
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': ['light.woonkamer_led_vide'], 'brightness': 187, 'transition': 0}}
2021-04-26 20:36:47 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: False
elevation: 2.88 (8.5, -18)
new brightness: 185
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 187}]
force_turn_on: True
Triggered by: state
to: (elevation: 2.88, azimuth: 289.58)
skip_event: True
last elevation: 2.88
new brightness: 185
last brightness: 185
force_turn_on: True
dim_entities: []
Triggered by: event
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': ['light.woonkamer_led_vide'], 'brightness': 185, 'transition': 0}}
2021-04-26 20:37:24 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: True
new brightness: 185
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 185}]
force_turn_on: True
dim_entities: []
Triggered by: event
entity_id: light.woonkamer_led_vide
service_data_length: 2
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': 'light.woonkamer_led_vide', 'brightness_pct': 38}}
2021-04-26 20:38:47 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: False
elevation: 2.61 (8.5, -18)
new brightness: 183
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 97}]
force_turn_on: True
Triggered by: state
to: (elevation: 2.61, azimuth: 289.97)
skip_event: True
last elevation: 2.61
new brightness: 183
last brightness: 183
force_turn_on: True
dim_entities: []
Triggered by: event
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': ['light.woonkamer_led_vide'], 'brightness': 183, 'transition': 0}}
2021-04-26 20:40:47 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: False
elevation: 2.34 (8.5, -18)
new brightness: 181
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 183}]
force_turn_on: True
Triggered by: state
to: (elevation: 2.34, azimuth: 290.36)
2021-04-26 20:40:48 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: True
last elevation: 2.34
new brightness: 181
last brightness: 181
force_turn_on: True
dim_entities: []
Triggered by: event
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': ['light.woonkamer_led_vide'], 'brightness': 181, 'transition': 0}}
2021-04-26 20:42:47 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: False
elevation: 2.07 (8.5, -18)
new brightness: 179
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 181}]
force_turn_on: True
Triggered by: state
to: (elevation: 2.07, azimuth: 290.75)
2021-04-26 20:42:48 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: True
last elevation: 2.07
new brightness: 179
last brightness: 179
force_turn_on: True
dim_entities: []
Triggered by: event
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': ['light.woonkamer_led_vide'], 'brightness': 179, 'transition': 0}}
2021-04-26 20:44:47 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: False
elevation: 1.8 (8.5, -18)
new brightness: 177
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 179}]
force_turn_on: True
Triggered by: state
to: (elevation: 1.8, azimuth: 291.14)
skip_event: True
last elevation: 1.8
new brightness: 177
last brightness: 177
force_turn_on: True
dim_entities: []
Triggered by: event
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': ['light.woonkamer_led_vide'], 'brightness': 177, 'transition': 0}}
2021-04-26 20:46:47 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: False
elevation: 1.54 (8.5, -18)
last elevation: 1.8
new brightness: 175
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 177}]
force_turn_on: True
Triggered by: state
to: (elevation: 1.54, azimuth: 291.54)
skip_event: True
last elevation: 1.54
new brightness: 175
last brightness: 175
force_turn_on: True
dim_entities: []
Triggered by: event
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': ['light.woonkamer_led_vide'], 'brightness': 175, 'transition': 0}}
2021-04-26 20:48:47 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: False
elevation: 1.28 (8.5, -18)
new brightness: 173
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 175}]
force_turn_on: True
Triggered by: state
to: (elevation: 1.28, azimuth: 291.93)
skip_event: True
last elevation: 1.28
new brightness: 173
last brightness: 173
force_turn_on: True
dim_entities: []
Triggered by: event
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': ['light.woonkamer_led_vide'], 'brightness': 173, 'transition': 0}}
2021-04-26 20:50:47 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: False
elevation: 1.03 (8.5, -18)
new brightness: 171
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 173}]
force_turn_on: True
Triggered by: state
to: (elevation: 1.03, azimuth: 292.32)
skip_event: True
last elevation: 1.03
new brightness: 171
last brightness: 171
force_turn_on: True
dim_entities: []
Triggered by: event
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': ['light.woonkamer_led_vide'], 'brightness': 171, 'transition': 0}}
2021-04-26 20:52:47 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: False
elevation: 0.78 (8.5, -18)
new brightness: 169
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 171}]
force_turn_on: True
Triggered by: state
to: (elevation: 0.78, azimuth: 292.72)
skip_event: True
last elevation: 0.78
new brightness: 169
last brightness: 169
force_turn_on: True
dim_entities: []
Triggered by: event
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': ['light.woonkamer_led_vide'], 'brightness': 169, 'transition': 0}}
2021-04-26 20:54:47 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: False
elevation: 0.54 (8.5, -18)
new brightness: 167
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 169}]
force_turn_on: True
Triggered by: state
to: (elevation: 0.54, azimuth: 293.11)
skip_event: True
last elevation: 0.54
new brightness: 167
last brightness: 167
force_turn_on: True
dim_entities: []
Triggered by: event
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': ['light.woonkamer_led_vide'], 'brightness': 167, 'transition': 0}}
2021-04-26 20:56:47 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: False
elevation: 0.3 (8.5, -18)
new brightness: 165
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 167}]
force_turn_on: True
Triggered by: state
to: (elevation: 0.3, azimuth: 293.51)
skip_event: True
last elevation: 0.3
new brightness: 165
last brightness: 165
force_turn_on: True
dim_entities: []
Triggered by: event
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': ['light.woonkamer_led_vide'], 'brightness': 165, 'transition': 0}}
2021-04-26 20:58:28 DEBUG (MainThread) [homeassistant.components.blueprint.dim_lights_based_on_sun_elevation] DEBUG:
skip_event: False
elevation: 0.1 (8.5, -18)
last elevation: 0.3
new brightness: 164
current_states: [{'entity_id': 'light.woonkamer_led_vide', 'state': 'on', 'brightness': 165}]
force_turn_on: True
Triggered by: state
to: (elevation: 0.1, azimuth: 293.84)
skip_event: True
last elevation: 0.1
new brightness: 164
last brightness: 164
force_turn_on: True
dim_entities: []
Triggered by: event
complete event data: {'domain': 'light', 'service': 'turn_on', 'service_data': {'entity_id': ['light.woonkamer_led_vide'], 'brightness': 164, 'transition': 0}}
I’m running this on my own server. Which has a Pentium(R) CPU G4560 with 8GB of memory and an SSD (those are the most important bits I think)
