I’m using Voice PE. I have multiple hue lights in the room.
If I have 2 lights turned off, 1 light at 90% and one light at 50% and I say: set brightness to 40%, then … all 4 lights in the room will turn on at 40%. Which is … correct based on the light.set command … but … this is not what I want.
How could I do to give commands (which make use of the area/room awareness) like: decrease/increase brightness and to refer only to the lights which are ON and to decrease/increase individual brightness of each light (not all of them to the same value) ?
