Dim lights only when Plex is playing on Chromecast
Hey all I’m trying to have my lights turn on and off depending on only if Plex is playing on a specific Chromecast. I have it working without the Plex condition just fine e.g…
# When Plex plays to "CR Chromecast" turn off Computer Room lights
- alias: "Media starts, lights off"
    - platform: state
      entity_id: media_player.cr_chromecast
      to: 'playing'
    service: scene.turn_on
    entity_id: scene.media_play
I imagine the condition would go something like the following (in English):
    - platform: state
      to: 'playing'
  condition:
    "stream source equals plex"
I am unsure of what the correct syntax would be. Is there some documentation to point me to, I couldn’t find any or has someone accomplished this before? I’d don’t want my computer room lights to not turn off if I’m simply throwing a quick YouTube video, or casting music. I am pretty sure I have Plex connected correctly as “sensor.plex” is showing up as an entity_id that gives the number of current streams. Any help would be appreciated!
Thanks!
Are you using the Plex component? If so, use that media_player as the trigger instead of Chromecast and don’t bother with the condition
I just did something similar with the plex media player component. Trigger was the plex media player on the xbox, conditions were that the xbox was on and the lights were on. The action was to change the brightness of the lights right down during playing, lighter during paused and full lights during idle.
I must not have the plex component working then. I never see a media_player.plex or media_player.plex_server_name in my entity list. I’ll need to dig since I don’t see any errors in home_assistant.log.
I have the following setup for Netflix which is working great:
- alias: 'Dim lights when playing Netflix in Living Room'
    platform: state
    entity_id: media_player.living_room
    to: 'playing'
  condition:
    condition: and
    conditions:
    - condition: sun
      after: sunset
      after_offset: "-0:20:00"
    - condition: template
      value_template: '{{  states.media_player.living_room.attributes.app_name == Netflix  }}'
    entity_id: scene.netflix_and_chill
Scene.netflix_and_chill lol!! Love it! @Bob_NL
Thanks Bob_NL, i’ll give this a try.
Thanks for the help everyone. I was able to get this working. Here is the example script in case any one in the future comes across it. I followed Bob_NL’x example, but for some reason my condition needed the quotes around Plex. Tested against other casting apps besides Plex and they did not trigger the automation rule.
    - platform: state
      to: 'playing'
  condition:
    condition: template
    value_template: '{{  states.media_player.cr_chromecast.attributes.app_name == "Plex"  }}'
Just to note that I also needed the quotations.
