πŸ’‘ Dim to Warm – Automatic color temperature when dimming smart bulbs
:light_bulb: Dim to Warm –
Open your Home Assistant instance and show the blueprint import dialog with this blueprint pre-filled.
Emulates the behavior of incandescent bulbs where dimming produces a warmer glow. Works with any smart light that has adjustable color temperature.
What it does
When you dim a light down, the color temperature automatically shifts warmer (lower Kelvin). When you turn it up, it shifts cooler. This mimics how traditional incandescent and halogen bulbs naturally behave.
Features:
  • Select multiple lights in a single automation – only the light that changed gets updated
  • Configurable Kelvin range (e.g. only use 2500–3500K even if the bulb supports 2200–5000K)
  • Brightness zones: define flat regions at the top and bottom where Kelvin stays constant
  • Linear interpolation in the transition zone between
  • Loop prevention with 25K deadband
  • Optional apply-on-turn-on
  • Uses color_temp_kelvin (future-proof, no deprecated mireds)
How the zones work
Brightness %    Color Temperature
    0% ─┐
       β”‚  Lower zone β†’ Min Kelvin (constant, warm)
   10% β”€β”˜
       β”‚  Transition zone β†’ Linear interpolation
   90% ─┐
       β”‚  Upper zone β†’ Max Kelvin (constant, cool)
  100% β”€β”˜
Example with defaults (min=2500K, max=4000K, lower=10%, upper=90%):
  • 0–10% brightness β†’ 2500 K (warm, constant)
  • 10–90% brightness β†’ 2500–4000 K (smooth transition)
  • 90–100% brightness β†’ 4000 K (cool, constant)
Requirements
  • Home Assistant 2024.6.0 or later
  • Lights with adjustable color temperature
Blueprint code
blueprint:
  name: "Dim to Warm"
  description: >
    Automatically links brightness to color temperature – the lower the
    brightness, the warmer (lower Kelvin) the light, and vice versa.
    Select one or more lights. All lights share the same Kelvin range
    and brightness zone settings. When a light's brightness changes,
    only that specific light's color temperature is updated.
    Configure:
    β€’ Min Kelvin (warmest) and Max Kelvin (coolest)
    β€’ Lower zone – below this brightness % min Kelvin is held constant
    β€’ Upper zone – above this brightness % max Kelvin is held constant
    β€’ In between, color temperature is interpolated linearly
      0–10 %  brightness β†’ 2500 K (warm, constant)
      10–90 % brightness β†’ 2500–4000 K (linear transition)
      90–100 % brightness β†’ 4000 K (cool, constant)
  domain: automation
  author: "robblids"
  source_url: "https://github.com/robblids/ha-dim-to-warm/blob/main/dim_to_warm.yaml"
  homeassistant:
    min_version: "2024.6.0"
  input:
    # ── Lights ───────────────────────────────────────────────
    light_section:
      icon: mdi:lightbulb-group
      description: "Select lights and configure the Kelvin range."
      collapsed: false
      input:
        target_lights:
          description: >
            Select one or more lights to apply dim-to-warm to.
            All selected lights will share the same settings.
          selector:
            entity:
              domain: light
              multiple: true
        min_kelvin:
          name: "Min Kelvin (warmest)"
          description: >
            Lowest color temperature. Used when brightness
            is at or below the lower zone.
          default: 2500
          selector:
            color_temp:
              unit: kelvin
              min: 1800
              max: 6500
        max_kelvin:
          name: "Max Kelvin (coolest)"
          description: >
            Highest color temperature. Used when brightness
            is at or above the upper zone.
          default: 4000
          selector:
            color_temp:
              unit: kelvin
              min: 1800
              max: 6500
    # ── Zones ────────────────────────────────────────────────
    zone_section:
      icon: mdi:chart-bell-curve-cumulative
      description: >
        Define the brightness ranges where color temperature
        is held constant (lower/upper zone) or interpolated.
      collapsed: false
      input:
        lower_zone:
          name: "Lower zone (%)"
          description: >
            Below this brightness percentage, min Kelvin is always used.
            The transition zone starts at this value.
          default: 10
          selector:
            number:
              min: 0
              max: 99
              step: 1
              unit_of_measurement: "%"
              mode: slider
        upper_zone:
          name: "Upper zone (%)"
          description: >
            Above this brightness percentage, max Kelvin is always used.
            The transition zone ends at this value.
          default: 90
          selector:
            number:
              min: 1
              max: 100
              step: 1
              mode: slider
    # ── Behavior ─────────────────────────────────────────────
    behavior_section:
      icon: mdi:cog
      description: "Additional settings for the automation."
      collapsed: true
      input:
        transition_time:
          description: >
            Time in seconds for the color temperature change.
            Set to 0 for instant changes.
          default: 0.5
          selector:
            number:
              min: 0
              max: 10
              step: 0.5
              unit_of_measurement: "s"
              mode: slider
        apply_on_turn_on:
          name: "Apply on turn on"
          description: >
            Also apply dim-to-warm immediately when a light
            is turned on (not only on brightness changes).
          default: true
          selector:
            boolean: {}
#  Variables
variables:
  all_lights: !input target_lights
  v_min_kelvin: !input min_kelvin
  v_max_kelvin: !input max_kelvin
  v_lower_zone: !input lower_zone
  v_upper_zone: !input upper_zone
  v_transition: !input transition_time
  apply_on_turn_on: !input apply_on_turn_on
  # The entity that triggered the automation
  changed_light: "{{ trigger.entity_id }}"
  # Calculate target Kelvin based on the triggering light's brightness
  target_kelvin: >
    {% set br = state_attr(changed_light, 'brightness') | default(0) | float(0) %}
    {% set pct = (br / 255 * 100) | round(1) %}
    {% set min_k = v_min_kelvin | float(2500) %}
    {% set max_k = v_max_kelvin | float(4000) %}
    {% set lower = v_lower_zone | float(10) %}
    {% set upper = v_upper_zone | float(90) %}
    {% if lower >= upper %}
      {{ ((min_k + max_k) / 2) | round(0) }}
    {% elif pct <= lower %}
      {{ min_k | round(0) }}
    {% elif pct >= upper %}
      {{ max_k | round(0) }}
    {% else %}
      {% set ratio = (pct - lower) / (upper - lower) %}
      {{ (min_k + ratio * (max_k - min_k)) | round(0) }}
    {% endif %}
  # Current Kelvin on the light – to avoid unnecessary calls
  current_kelvin: >
    {{ state_attr(changed_light, 'color_temp_kelvin') | default(0) | float(0) }}
  # Only update if difference > 25K (prevents loops)
  should_update: >
    {{ (target_kelvin | float(0) - current_kelvin | float(0)) | abs > 25 }}
#  Triggers
triggers:
  # Brightness changed on any of the selected lights
  - trigger: state
    entity_id: !input target_lights
    attribute: brightness
  # Any of the selected lights turned on
  - trigger: state
    to: "on"
#  Conditions
conditions:
  # The triggering light must be on
  - condition: template
    value_template: "{{ is_state(changed_light, 'on') }}"
  # Check if we should apply on turn-on events
  - condition: or
    conditions:
      - condition: trigger
      - condition: and
        conditions:
            value_template: "{{ apply_on_turn_on }}"
#  Actions
mode: queued
max: 10
actions:
  # Short delay to let brightness stabilize
  - delay:
      milliseconds: 150
  # Only proceed if an update is actually needed
    value_template: "{{ should_update }}"
  # Set color temperature on the specific light that changed
  - action: light.turn_on
      entity_id: "{{ changed_light }}"
      color_temp_kelvin: "{{ target_kelvin | int }}"
      transition: "{{ v_transition | float(0.5) }}"
GitHub: GitHub - robblids/ha-dim-to-warm: Simple blueprint to make your smart lights adapt its temperature to brightness Β· GitHub
