Remote using scripts for mqtt calls to infrared blaster
Updates do not seem to be pulled into this project anymore but I think we need some more offbeat examples to be recorded somewhere. So I am adding here the code for the following.
I have created a remote for Roku Premiere. When a button is clicked, an Mqtt message is published, containing the ir string and, in my case, a zigbee2mqtt sonoff ir blaster processes this and sends the ir signal. You will need to record the relevant ir codes and represent these in secrets.yaml. I found mine using the “learn” exposed option for my blaster in zigbee2mqtt. For posting purposes, I have overwritten my full ir codes with dummy texts.
Note also that, in this case, I have png files overriding the Netflix/Amazon/etc buttons as my remote has different apps represented.
See png files link for all png files used.
Dashboard card code:
type: custom:generic-remote-control-card
show_header_toggle: false
view_layout:
grid-area: remote1
remote_template: rokupremiere
buttons:
leftarrow:
call: script.living_room_ir_button
button_pressed: '{{ states("input_text.rokupremiere_leftarrow_text") }}'
home:
button_pressed: '{{ states("input_text.rokupremiere_home_text") }}'
up:
button_pressed: '{{ states("input_text.rokupremiere_up_text") }}'
down:
button_pressed: '{{ states("input_text.rokupremiere_down_text") }}'
left:
button_pressed: '{{ states("input_text.rokupremiere_left_text") }}'
right:
button_pressed: '{{ states("input_text.rokupremiere_right_text") }}'
ok:
button_pressed: '{{ states("input_text.rokupremiere_ok_text") }}'
replay:
button_pressed: '{{ states("input_text.rokupremiere_replay_text") }}'
asterisk:
button_pressed: '{{ states("input_text.rokupremiere_asterisk_text") }}'
rewind:
button_pressed: '{{ states("input_text.rokupremiere_rewind_text") }}'
playpause:
button_pressed: '{{ states("input_text.rokupremiere_playpause_text") }}'
forward:
button_pressed: '{{ states("input_text.rokupremiere_forward_text") }}'
netflix:
button_pressed: '{{ states("input_text.rokupremiere_netflix_text") }}'
googleplay:
button_pressed: '{{ states("input_text.rokupremiere_googleplay_text") }}'
rakuten:
button_pressed: '{{ states("input_text.rokupremiere_rakuten_text") }}'
spotify:
button_pressed: '{{ states("input_text.rokupremiere_spotify_text") }}'
script.yaml (written as global script for any remote using zigbee2mqtt processing):
living_room_ir_button:
sequence:
- service: mqtt.publish
topic: zigbee2mqtt/Living Room Zigbee IR Remote Control/set
payload_template: '{ "ir_code_to_send": "{{ button_pressed }}" }'
alias: Living Room Ir Button
mode: single
input_texts.yaml:
# roku ir codes
rokupremiere_leftarrow_text:
initial: !secret rokupremiere_leftarrow
min: 0
max: 255
rokupremiere_home_text:
initial: !secret rokupremiere_home
min: 0
max: 255
rokupremiere_up_text:
initial: !secret rokupremiere_up
min: 0
max: 255
rokupremiere_down_text:
initial: !secret rokupremiere_down
min: 0
max: 255
rokupremiere_left_text:
min: 0
max: 255
rokupremiere_right_text:
initial: !secret rokupremiere_right
min: 0
max: 255
rokupremiere_ok_text:
initial: !secret rokupremiere_ok
min: 0
max: 255
rokupremiere_replay_text:
initial: !secret rokupremiere_replay
min: 0
max: 255
rokupremiere_asterisk_text:
initial: !secret rokupremiere_asterisk
min: 0
max: 255
rokupremiere_rewind_text:
initial: !secret rokupremiere_rewind
min: 0
max: 255
rokupremiere_playpause_text:
initial: !secret rokupremiere_playpause
min: 0
max: 255
rokupremiere_forward_text:
initial: !secret rokupremiere_forward
min: 0
max: 255
rokupremiere_netflix_text:
initial: !secret rokupremiere_netflix
min: 0
max: 255
rokupremiere_googleplay_text:
initial: !secret rokupremiere_googleplay
min: 0
max: 255
rokupremiere_rakuten_text:
initial: !secret rokupremiere_rakuten
min: 0
max: 255
rokupremiere_spotify_text:
initial: !secret rokupremiere_spotify
min: 0
max: 255
secrets.yaml:
rokupremiere_leftarrow: dummy1
rokupremiere_home: dummy2
rokupremiere_up: dummy3
rokupremiere_down: dummy4
rokupremiere_left: dummy5
rokupremiere_right: dummy6
rokupremiere_ok: dummy7
rokupremiere_replay: dummy8
rokupremiere_asterisk: dummy9
rokupremiere_rewind: dummy10
rokupremiere_playpause: dummy11
rokupremiere_forward: dummy12
rokupremiere_netflix: dummy13
rokupremiere_googleplay: dummy14
rokupremiere_rakuten: dummy15
rokupremiere_spotify: dummy16
remote-html.js:
function getRemoteStyle_rokupremiere(config) {
const template = config.remote_template;
const base_url = `/hacsfiles/generic-remote-control-card/remotes/${template}`;
return `
ha-card{
background-color:transparent;
box-shadow:var(--paper-material-elevation-0_-_box-shadow);
body {
margin: 0;
padding: 0px;
font-family: "Helvetica Neue", Helvetica, Arial, Geneva, sans-serif
.container {
width: 242px;
margin: 0 auto
#remote-control-rokupremiere {
position: relative;
background: url(${base_url}/rokupremiere.png?1) no-repeat;
width: 242px;
height: 720px
#remote-control-rokupremiere ul {
margin: 0;
padding: 0;
list-style-type: none
#forward a,
#rewind a,
#playpause a,
#left a,
#right a,
#up a,
#down a,
#ok a,
#asterisk a,
#rakuten a,
#spotify a,
#text a,
#googleplay a,
#netflix a,
#leftarrow a,
#home a,
#replay a {
position: absolute;
display: block
#remote-control-rokupremiere li#rewind a {
left: 54px;
top: 369px;
width: 30px;
height: 18px;
background: url(${base_url}/rewind.png?1) no-repeat
#remote-control-rokupremiere li#forward a {
left: 157px;
top: 369px;
width: 30px;
height: 18px;
background: url(${base_url}/forward.png?1) no-repeat
#remote-control-rokupremiere li#playpause a {
left: 109px;
top: 370px;
width: 24px;
height: 18px;
background: url(${base_url}/playpause.png?1) no-repeat
#remote-control-rokupremiere li#left a {
left: 54px;
top: 207px;
width: 24px;
height: 27px;
background: url(${base_url}/left.png?1) no-repeat
#remote-control-rokupremiere li#right a {
left: 157px;
top: 207px;
width: 24px;
height: 27px;
background: url(${base_url}/right.png?1) no-repeat
#remote-control-rokupremiere li#up a {
left: 102px;
top: 162px;
width: 37px;
height: 18px;
background: url(${base_url}/up.png?1) no-repeat
#remote-control-rokupremiere li#down a {
left: 102px;
top: 261px;
width: 37px;
height: 18px;
background: url(${base_url}/down.png?1) no-repeat
#remote-control-rokupremiere li#ok a {
left: 102px;
top: 207px;
width: 37px;
height: 27px;
background: url(${base_url}/ok.png?1) no-repeat
#remote-control-rokupremiere li#asterisk a {
left: 145px;
top: 315px;
width: 30px;
height: 27px;
background: url(${base_url}/asterisk.png?1) no-repeat
#remote-control-rokupremiere li#rakuten a {
left: 48px;
top: 483px;
width: 64px;
height: 33px;
background: url(${base_url}/rakuten.png?1) no-repeat
#remote-control-rokupremiere li#spotify a {
left: 127px;
top: 483px;
width: 64px;
height: 32px;
background: url(${base_url}/spotify.png?1) no-repeat
#remote-control-rokupremiere li#googleplay a {
left: 127px;
top: 434px;
width: 65px;
height: 34px;
background: url(${base_url}/googleplay.png?1) no-repeat 0 0px
#remote-control-rokupremiere li#netflix a {
left: 48px;
top: 434px;
width: 64px;
height: 34px;
background: url(${base_url}/netflix.png?1) no-repeat 0 0px
#remote-control-rokupremiere li#leftarrow a {
left: 66px;
top: 99px;
width: 30px;
height: 27px;
background: url(${base_url}/leftarrow.png?1) no-repeat
#remote-control-rokupremiere li#home a {
left: 145px;
top: 99px;
width: 30px;
height: 27px;
background: url(${base_url}/home.png?1) no-repeat
#remote-control-rokupremiere li#replay a {
left: 67px;
top: 315px;
width: 30px;
height: 27px;
background: url(${base_url}/replay.png?1) no-repeat
#remote-control-rokupremiere li#playpause a:hover {
background: url(${base_url}/playpause_over.png?1) no-repeat 0px 0px
#remote-control-rokupremiere li#rewind a:hover {
background: url(${base_url}/rewind_over.png?1) no-repeat 0px 0px
#remote-control-rokupremiere li#forward a:hover {
background: url(${base_url}/forward_over.png?1) no-repeat 0px 0px
#remote-control-rokupremiere li#left a:hover {
background: url(${base_url}/left_over.png?1) no-repeat 0px 0px
#remote-control-rokupremiere li#right a:hover {
background: url(${base_url}/right_over.png?1) no-repeat 0px 0px
#remote-control-rokupremiere li#up a:hover {
background: url(${base_url}/up_over.png?1) no-repeat 0px 0px
#remote-control-rokupremiere li#down a:hover {
background: url(${base_url}/down_over.png?1) no-repeat 0px 0px
#remote-control-rokupremiere li#ok a:hover {
background: url(${base_url}/ok_over.png?1) no-repeat 0px 0px
#remote-control-rokupremiere li#asterisk a:hover {
background: url(${base_url}/asterisk_over.png?1) no-repeat 0px 0px
#remote-control-rokupremiere li#rakuten a:hover {
background: url(${base_url}/rakuten_over.png?1) no-repeat 0px 0px
#remote-control-rokupremiere li#spotify a:hover {
background: url(${base_url}/spotify_over.png?1) no-repeat 0px 0px
#remote-control-rokupremiere li#googleplay a:hover {
background: url(${base_url}/googleplay_over.png?1) no-repeat 0 0px
#remote-control-rokupremiere li#netflix a:hover {
background: url(${base_url}/netflix_over.png?1) no-repeat 0 0px
#remote-control-rokupremiere li#leftarrow a:hover {
background: url(${base_url}/leftarrow_over.png?1) no-repeat 0 0px
#remote-control-rokupremiere li#home a:hover {
background: url(${base_url}/home_over.png?1) no-repeat 0 0px
#remote-control-rokupremiere li#replay a:hover {
background: url(${base_url}/replay_over.png?1) no-repeat 0 0px
#remote-control-rokupremiere li#tv a:hover {
background: url(${base_url}/tv_over.png?1) no-repeat 0px 0px
function getRemoteHtml_rokupremiere(config){
return `
<div class="container">
<div style="text-align:center">
<h1>${config.name}</h1>
</div>
<div id="remote-control-rokupremiere">
<ul>
<li class="myButton-${template}" id="playpause"><a href="#" title="playpause"></a></li>
<li class="myButton-${template}" id="rewind"><a href="#" title="rewind"></a></li>
<li class="myButton-${template}" id="play"><a href="#" title="play"></a></li>
<li class="myButton-${template}" id="forward"><a href="#" title="forward"></a></li>
<li class="myButton-${template}" id="googleplay"><a href="#" title="googleplay"></a></li>
<li class="myButton-${template}" id="netflix"><a href="#" title="netflix"></a></li>
<li class="myButton-${template}" id="leftarrow"><a href="#" title="leftarrow"></a></li>
<li class="myButton-${template}" id="home"><a href="#" title="home"></a></li>
<li class="myButton-${template}" id="replay"><a href="#" title="replay"></a></li>
<li class="myButton-${template}" id="asterisk"><a href="#" title="asterisk"></a></li>
<li class="myButton-${template}" id="rakuten"><a href="#" title="rakuten"></a></li>
<li class="myButton-${template}" id="spotify"><a href="#" title="spotify"></a></li>
<li class="myButton-${template}" id="ok"><a href="#" title="ok"></a></li>
<li class="myButton-${template}" id="left"><a href="#" title="left"></a></li>
<li class="myButton-${template}" id="right"><a href="#" title="right"></a></li>
<li class="myButton-${template}" id="up"><a href="#" title="up"></a></li>
<li class="myButton-${template}" id="down"><a href="#" title="down"></a></li>
</ul>
</div>
</div>
