Dimmable and white spectrum control bulb (like IKEA TRADFRI 1100/1055/1160) with IKEA STYRBAR (E2001/E2002) on zigbee2mqtt
Hi. I was frustrated that I couldn’t make a seemingly simple config to control IKEA bulbs with IKEA Styrbar controller.
Binding doesn’t work for new models, and the “Awesome” HA Blueprints do not work for me at all (and many others), and the complexity of it is immense when I tried to debug it.
So here I have a simple automation (no, it’s not even a blueprint, suit yourself) that implements what I wanted, with the behavior of IKEA lights and controllers (3 scenes: warm, normal, cold).
You need to manually create a scene helper of type input number with range from 0 to 1.
alias: Children/Juli ceiling light controller
description: ""
  - platform: state
    entity_id:
      - sensor.potatotheta_action
    attribute: action
    to:
      - "on"
      - "off"
      - arrow_left_click
      - arrow_right_click
      - brightness_move_down
      - brightness_move_up
      - brightness_stop
condition: []
  - variables:
      command: "{{ trigger.to_state.state }}"
      low_brightness: 10
      default_brightness: 20
      high_brightness: 100
      step_pct: 10
      speed: 300
      light: light.childrenceilinglight
      scene: "{{ states('input_number.children_scene') | int }}"
      warm: 2202
      day: 3000
      cold: 4000
  - choose:
      - conditions:
          - condition: template
            value_template: "{{ command == 'on' }}"
        sequence:
          - service: light.turn_on
              entity_id: "{{ light }}"
              brightness_pct: "{{ default_brightness }}"
      - conditions:
            value_template: "{{ command == 'off' }}"
        sequence:
          - service: light.turn_off
      - conditions:
            value_template: "{{ command == 'brightness_move_up' }}"
        sequence:
          - repeat:
              while: []
              sequence:
                    brightness_step_pct: "{{ step_pct | int }}"
                    transition: "{{ (speed / 1000) | float }}"
                - delay:
                    milliseconds: "{{ speed }}"
      - conditions:
            value_template: "{{ command == 'brightness_move_down' }}"
        sequence:
          - repeat:
              while: []
              sequence:
                    brightness_step_pct: >
                      {% set current_brightness = state_attr(light,
                      'brightness') | default(0) | int %} {% set new_brightness
                      = current_brightness - (step_pct * 2.55) %} {% if
                      new_brightness < (low_brightness * 2.55) %}
                        {{ -((current_brightness - (low_brightness * 2.55)) / 2.55) | int }}
                      {% else %}
                        {{ -step_pct | int }}
                      {% endif %}
                - delay:
      - conditions:
            value_template: "{{ command == 'arrow_right_click' }}"
        sequence:
          - choose:
              - conditions:
                    value_template: "{{ scene < 2 }}"
                sequence:
                  - service: input_number.set_value
                      entity_id: input_number.children_scene
                      value: "{{ scene + 1 }}"
              kelvin: |
                {% if scene == 0 %}
                  {{ day }}
                {% else %}
                  {{ cold }}
                {% endif %}
      - conditions:
            value_template: "{{ command == 'arrow_left_click' }}"
        sequence:
          - choose:
              - conditions:
                    value_template: "{{ scene > 0 }}"
                sequence:
                      value: "{{ scene - 1 }}"
              kelvin: |
                {% if scene == 2 %}
                  {{ day }}
                {% else %}
                  {{ warm }}
                {% endif %}
    default: []
mode: restart
