Hi. I have a CCT LED strip (warm and cold), and I have them connected to Shelly RGBW2 to individual channels, I wanted to combine the control of them mimicking a single light, controlled by IKEA STYRBAR with the behavior of IKEA lights and controllers (3 scenes: warm, normal, cold).
You need to manually create a scene helper of type input number with range from 0 to 1.
Here it is:
alias: Downstair bathroom mirror light controller
description: ""
- platform: state
entity_id:
- sensor.potatozeta_action
attribute: action
to:
- "on"
- "off"
- arrow_left_click
- arrow_right_click
- brightness_move_down
- brightness_move_up
- brightness_stop
condition: []
- variables:
command: "{{ trigger.to_state.state }}"
low_brightness: 1
default_brightness: 20
high_brightness: 100
step_pct: 5
speed: 300
warm_channel: light.downstairs_bathroom_channel_4
cold_channel: light.downstairs_bathroom_channel_3
scene: "{{ states('input_number.mirror_scene') | int }}"
current_visible_brightness: >-
{{ (state_attr('light.downstair_bathroom_mirror', 'brightness') or 0) /
2.55 }}
- choose:
- conditions:
- condition: template
value_template: "{{ command == 'on' }}"
sequence:
- service: light.turn_on
entity_id: |
{% if scene == 0 %}
{{ warm_channel }}
{% elif scene == 1 %}
{{ warm_channel }}, {{ cold_channel }}
{% elif scene == 2 %}
{{ cold_channel }}
{% endif %}
brightness_pct: "{{ default_brightness }}"
- conditions:
value_template: "{{ command == 'off' }}"
sequence:
- service: light.turn_off
entity_id: |
{% if scene == 0 %}
{{ warm_channel }}
{{ cold_channel }}
{% endif %}
- conditions:
value_template: "{{ command == 'brightness_move_up' }}"
sequence:
- repeat:
while: []
sequence:
entity_id: |
{% if scene == 0 %}
{{ warm_channel }}
{{ cold_channel }}
{% endif %}
brightness_step_pct: "{{ step_pct | int }}"
transition: "{{ (speed / 1000) | float }}"
- delay:
milliseconds: "{{ speed }}"
- conditions:
value_template: "{{ command == 'brightness_move_down' }}"
sequence:
- repeat:
while: []
sequence:
- variables:
current_brightness_warm: "{{ (state_attr(warm_channel, 'brightness') or 0) | int }}"
current_brightness_cold: "{{ (state_attr(cold_channel, 'brightness') or 0) | int }}"
new_brightness_warm: >-
{{ [current_brightness_warm - (step_pct * 2.55),
low_brightness * 2.55] | max }}
new_brightness_cold: >-
{{ [current_brightness_cold - (step_pct * 2.55),
new_brightness: "{{ [new_brightness_cold, new_brightness_warm] | min}}"
entity_id: >
{% set warm_on = is_state(warm_channel, 'on') %} {% set
cold_on = is_state(cold_channel, 'on') %} {% if warm_on
and cold_on %}
{{ [warm_channel, cold_channel] | join(', ') }}
{% elif warm_on %}
{{ warm_channel }}
{% elif cold_on %}
{{ cold_channel }}
{% else %}
none
{% endif %}
brightness: "{{ new_brightness }}"
- delay:
- conditions:
value_template: "{{ command == 'arrow_right_click' }}"
sequence:
- choose:
- conditions:
value_template: "{{ scene < 2 }}"
sequence:
- service: input_number.set_value
entity_id: input_number.mirror_scene
value: "{{ scene + 1 }}"
- choose:
- conditions:
value_template: "{{ (scene == 0) }}"
sequence:
parallel:
entity_id:
- "{{ cold_channel }}"
- "{{ warm_channel }}"
brightness_pct: "{{ current_visible_brightness }}"
- conditions:
value_template: "{{ scene == 2 or scene == 1 }}"
sequence:
entity_id: "{{ cold_channel }}"
entity_id: "{{ warm_channel }}"
- conditions:
value_template: "{{ command == 'arrow_left_click' }}"
sequence:
- choose:
- conditions:
value_template: "{{ scene > 0 }}"
sequence:
value: "{{ scene - 1 }}"
- choose:
- conditions:
value_template: "{{ (scene == 0) or (scene == 1) }}"
sequence:
- parallel:
- conditions:
value_template: "{{ scene == 2 }}"
sequence:
entity_id:
default: []
mode: restart
