I have some dimmable bulbs and when turning them off, I see z-wave updates and levels as it dims to off of 66 and 33, but never the final 0 to indicate off. My HA UI never shows completely off until I toggle it to off again.
Are these updates I am seeing being sent as updates by the bulb or does HA send update requests and is just not sending enough to get the last final value for when it is off.
I am just not familiar enough about the process for this.
Here is what I see during an on to off transition.
2019-03-10 18:03:35.765 Info, Node004, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 0
2019-03-10 18:03:35.765 Info, Node004, SwitchMultilevel::Set - Setting to level 0
2019-03-10 18:03:35.769 Detail, Node004, Queuing (Send) SwitchMultilevelCmd_Set (Node=4): 0x01, 0x0a, 0x00, 0x13, 0x04, 0x03, 0x26, 0x01, 0x00, 0x25, 0xfb, 0x18
2019-03-10 18:03:35.769 Detail, Node004, Queuing (Send) SwitchMultilevelCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x26, 0x02, 0x25, 0xfc, 0x1e
2019-03-10 18:03:35.769 Info, Node004, Sending (Send) message (Callback ID=0xfb, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=4): 0x01, 0x0a, 0x00, 0x13, 0x04, 0x03, 0x26, 0x01, 0x00, 0x25, 0xfb, 0x18
2019-03-10 18:03:35.778 Detail, Node004, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-03-10 18:03:35.779 Detail, Node004, ZW_SEND_DATA delivered to Z-Wave stack
2019-03-10 18:03:35.794 Detail, Node004, Received: 0x01, 0x07, 0x00, 0x13, 0xfb, 0x00, 0x00, 0x02, 0x12
2019-03-10 18:03:35.794 Detail, Node004, ZW_SEND_DATA Request with callback ID 0xfb received (expected 0xfb)
2019-03-10 18:03:35.794 Info, Node004, Request RTT 24 Average Request RTT 24
2019-03-10 18:03:35.795 Detail, Node004, Removing current message
2019-03-10 18:03:35.801 Info, Node004, Sending (Send) message (Callback ID=0xfc, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x26, 0x02, 0x25, 0xfc, 0x1e
2019-03-10 18:03:35.810 Detail, Node004, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-03-10 18:03:35.810 Detail, Node004, ZW_SEND_DATA delivered to Z-Wave stack
2019-03-10 18:03:35.825 Detail, Node004, Received: 0x01, 0x07, 0x00, 0x13, 0xfc, 0x00, 0x00, 0x02, 0x15
2019-03-10 18:03:35.826 Detail, Node004, ZW_SEND_DATA Request with callback ID 0xfc received (expected 0xfc)
2019-03-10 18:03:35.826 Info, Node004, Request RTT 24 Average Request RTT 24
2019-03-10 18:03:35.837 Detail, Node004, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x04, 0x03, 0x26, 0x03, 0x62, 0xb2
2019-03-10 18:03:35.837 Info, Node004, Response RTT 35 Average Response RTT 35
2019-03-10 18:03:35.837 Info, Node004, Received SwitchMultiLevel report: level=98
2019-03-10 18:03:35.838 Detail, Node004, Refreshed Value: old value=99, new value=98, type=byte
2019-03-10 18:03:35.838 Detail, Node004, Changes to this value are not verified
2019-03-10 18:03:35.838 Detail, Node004, Expected reply and command class was received
2019-03-10 18:03:35.838 Detail, Node004, Message transaction complete
2019-03-10 18:03:35.838 Detail, Node004, Removing current message
2019-03-10 18:03:35.839 Detail, Node004, Notification: ValueChanged
2019-03-10 18:03:36.773 Detail, Node004, Queuing (Send) SwitchMultilevelCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x26, 0x02, 0x25, 0xfd, 0x1f
2019-03-10 18:03:36.773 Info, Node004, Sending (Send) message (Callback ID=0xfd, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x26, 0x02, 0x25, 0xfd, 0x1f
2019-03-10 18:03:36.782 Detail, Node004, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-03-10 18:03:36.782 Detail, Node004, ZW_SEND_DATA delivered to Z-Wave stack
2019-03-10 18:03:36.797 Detail, Node004, Received: 0x01, 0x07, 0x00, 0x13, 0xfd, 0x00, 0x00, 0x02, 0x14
2019-03-10 18:03:36.797 Detail, Node004, ZW_SEND_DATA Request with callback ID 0xfd received (expected 0xfd)
2019-03-10 18:03:36.797 Info, Node004, Request RTT 23 Average Request RTT 23
2019-03-10 18:03:36.808 Detail, Node004, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x04, 0x03, 0x26, 0x03, 0x42, 0x92
2019-03-10 18:03:36.809 Info, Node004, Response RTT 35 Average Response RTT 35
2019-03-10 18:03:36.809 Info, Node004, Received SwitchMultiLevel report: level=66
2019-03-10 18:03:36.809 Detail, Node004, Refreshed Value: old value=98, new value=66, type=byte
2019-03-10 18:03:36.809 Detail, Node004, Changes to this value are not verified
2019-03-10 18:03:36.809 Detail, Node004, Expected reply and command class was received
2019-03-10 18:03:36.809 Detail, Node004, Message transaction complete
2019-03-10 18:03:36.809 Detail, Node004, Removing current message
2019-03-10 18:03:36.809 Detail, Node004, Notification: ValueChanged
2019-03-10 18:03:37.774 Detail, Node004, Queuing (Send) SwitchMultilevelCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x26, 0x02, 0x25, 0xfe, 0x1c
2019-03-10 18:03:37.774 Info, Node004, Sending (Send) message (Callback ID=0xfe, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x26, 0x02, 0x25, 0xfe, 0x1c
2019-03-10 18:03:37.783 Detail, Node004, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-03-10 18:03:37.783 Detail, Node004, ZW_SEND_DATA delivered to Z-Wave stack
2019-03-10 18:03:37.799 Detail, Node004, Received: 0x01, 0x07, 0x00, 0x13, 0xfe, 0x00, 0x00, 0x02, 0x17
2019-03-10 18:03:37.799 Detail, Node004, ZW_SEND_DATA Request with callback ID 0xfe received (expected 0xfe)
2019-03-10 18:03:37.800 Info, Node004, Request RTT 25 Average Request RTT 24
2019-03-10 18:03:37.809 Detail, Node004, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x04, 0x03, 0x26, 0x03, 0x21, 0xf1
2019-03-10 18:03:37.810 Info, Node004, Response RTT 35 Average Response RTT 35
2019-03-10 18:03:37.810 Info, Node004, Received SwitchMultiLevel report: level=33
2019-03-10 18:03:37.810 Detail, Node004, Refreshed Value: old value=66, new value=33, type=byte
2019-03-10 18:03:37.810 Detail, Node004, Changes to this value are not verified
2019-03-10 18:03:37.810 Detail, Node004, Expected reply and command class was received
2019-03-10 18:03:37.810 Detail, Node004, Message transaction complete
2019-03-10 18:03:37.810 Detail, Node004, Removing current message
2019-03-10 18:03:37.811 Detail, Node004, Notification: ValueChanged
