This is my first post and it is a pleasure to be on this forum. I am really interested in creating a smart home. I am re-doing my house at the moment and have put in double back boxes 47mm in all light switches with a neutral wire. I would like recommendation for smart switches that I can use to control my lights. They should allow me to dim and control from main switch and remotely. They should also be compatible with Home Assistant as I want to feed in my UFH and Radiator Evo home control into Home Assistant as well. With the light switches I want to have dimmable companion switches next to my bedside cabinet that can be used to control the switch. Please advise the switches you recommend and why. Thank you.
I don’t own any dimmers. I gave you the link so you could decide for yourself what you like and what suits your needs. Please click it and check for yourself.
