I have a dimmable light template that has an issue with it’s on/off state.
When I press the ‘on/off’ button at the state card when the light is off, it functions normally.
It turns the light on, and the brightness slider increases. Same thing when I press again to turn off.
However, when I first set the brightness with the slider, the bulb turns on. When I press the on/off button nothing happens. It seems that the “value_template” isn’t evaluated in this case.
My code:
bediening_licht_keukentafel:
unique_id: licht_keukentafel
friendly_name: "Licht keukentafel"
level_template: >
{{ states('sensor.brightness_licht_keukentafel') }}
value_template: >
{% if states('sensor.brightness_licht_keukentafel_raw')|int > 1 %}
True
{% else %}
False
{% endif %}
turn_on:
service: ads_custom.write_data_by_name
adsvar: gvlHomeAssistant.bBedLichtKeukentafel
adstype: byte
value: 1
turn_off:
adstype: byte
value: 0
set_level:
data_template:
adsvar: gvlHomeAssistant.btDimLichtKeukentafel
adstype: byte
value: >
{% set state = brightness | int / 2.55 %}
{% if state > 1 %}
{{ (log(state * 10, 10)*(253/3)+1) | round(0) }}
{% else %}
0
{% endif %}
I tried several things for the value_template like changing True / False, to on/off, or to evaluate it without if-then statement.
"{{ states('sensor.brightness_licht_keukentafel_raw')|int > 1}}"
Am I missing something?
