Dimmable RGBW leds, each color separate source
Hi there,
I’ve got dimmable RGBW strips where each color is managed separately. Means, HA doesn’t know the color, treats any of them as a simple dimmable light.
That’s how do I use them at the moment:
square: false
type: grid
cards:
  - features:
      - type: light-brightness
    type: tile
    entity: light.ledy_red
    color: red
    icon: mdi:alarm-light
    show_entity_picture: false
    vertical: false
  - features:
    type: tile
    entity: light.ledy_green
    color: green
    vertical: false
  - features:
    type: tile
    entity: light.ledy_blue
    color: blue
    vertical: false
  - features:
    type: tile
    entity: light.ledy_white
    color: lightgrey
    vertical: false
columns: 1
Having 4 sliders isn’t really efficient. I’d like to get this manageable via color wheel/pallete. Any suggestions how I could achieve this? The goal is to teach it how to mix the colors so I don’t have to mix them manually :slight_smile:
Best regards,
K.M.
Hi, i’ve the same situation, did you find a way to do this?
bye!
I’ve never done it, but WLED has support for RGB LEDs and there is an integration for WLED in Home Assistant.
Solved, not ideal. However, good starting point. Kudos to Home Assistant Polska Admin.
light:
    lights:
      rgbw:
        friendly_name: "rgbw"
        rgbw_template: |-
             state_attr('light.red', 'brightness'),
             state_attr('light.green', 'brightness'),
             state_attr('light.blue', 'brightness'),
             state_attr('light.white', 'brightness')
        turn_on:
          service: light.turn_on
          entity_id: light.red, light.green, light.blue, light.white
        turn_off:
          service: light.turn_off
        set_rgbw:
          service: script.set_rgbw
            r: "{{r}}"
            g: "{{g}}"
            b: "{{b}}"
            w: "{{w}}"
script:
  set_rgbw:
    sequence:
      - service: light.turn_on
          brightness: "{{r}}"
          entity_id: light.green
          brightness: "{{g}}"
          entity_id: light.blue
          brightness: "{{b}}"
          entity_id: light.white
          brightness: "{{w}}"
