Hi there!
I need your help for automating two ceiling lamps. One is the Foscarini Bahia and the other one is the Artemide Pirce.
Both lamps have the dimmer circuit inside, they power on (short press), off (short press) e dim (long press) via push button.
I would like to automate this push button in HA. What kind of device do I need?
Thanks in advance.
This is a loaded question…
- Do you have the hardware that automates these devices?
- Do you have a controller that can communicate with the hardware that automates the devices?
- Do you have home assistant running on any device?
- I think the hardware is the push button.
- I’m still looking for a way to control the push button
- yes, I have Hass.io running on a RPI 3 in another room.
What is the push button that you refer to? Do you have a model number? If you are speaking of the push button for the lamps you described, that is not the correct hardware. You need hardware that can talk over a network to a hub. There are many different styles; zwave, zigbee, wifi, RF… etc.
