Dimmer light - Only show as on/off?
Hi, I have a bathroom fan hooked up to a dimmer switch. As it shows as a light, I get on / off / set level in my cards.
Any way to set this light up as a light but only supporting on / off
or
Show it as a switch instead?
Use a switch template:
Here is an example if your existing entity was called light.fandimmer, and you wanted to create a switch named switch.fanswitch that you use can to simply toggle the fan on/off:
switch:
    switches:
      fanswitch:
        value_template: "{{ is_state('light.fandimmer', 'on') }}"
        turn_on:
          service: light.turn_on
            entity_id: light.fandimmer
            brightness_pct: 100
            transition: no
        turn_off:
          service: light.turn_off
            brightness_pct: 0
            transition: no
Haven’t tested this, but should work.
Thanks, got very close myself
switch:
    switches:
      bathroom_fan:
        friendly_name: Bathroom Fan
        icon_template: mdi:fan
        value_template: "{{ is_state('light.bathroom_fan', 'on') }}"
        turn_on:
            entity_id: light.bathroom_fan
            brightness: 255
        turn_off:
