Dimmer Switches & LEDs
Hi All,
Still slowly acquiring and adding entities, and having a bit of trouble with a dimmer in my kitchen. I am on the second one, a HomeSeer HS-WD100+ (the first was a WeMo Dimmer).
I have 9 can lights in my kitchen, hooked to the switch. I have 9 dimmable LEDs installed (CREE, but have tried other brands). The problem is they don’t dim. The switch is installed correctly, line, load, ground, and neutral. The weird thing is that when I replace ONE of the LEDs with an incandescent bulb they DO dim.
Has anyone else encountered something like this? Any suggestions?
Thanks,
-jamie
