Dimmer switches used to transition smoothly
I think I might be going nuts.
Prior to 2023.3 I swear my zigbee enbrighten dimmer switches would transition over roughly a second when I changed the brightness level via a tile card. Now suddenly the change is abrupt and jarring with no transition. I searched around and checked the change logs and didn’t find anything that would relate other than old posts about the transitions being a hardware feature from years ago. I can still go into the developer section and call for service to dim the lights over a transition time and that works fine. Has anyone else noticed this? Am I missing something?
Same here. Did you find a solution?
Nope. No idea what changed.
