Dimmer two halogen lamps of 230W
I want to dim the light of two halogen lamps. Total power (230Wx2=460W).
Each lamp provides 5000 lumens. I have not found an LED solution.
So, I need a dimmer with enough power.
Is there a Zigbee solution? Any suggestions? Or I need to create a Z-wave network? All the Zigbee solutions that I have found have low power.
What country/voltage?
Country: Spain
Voltage: 220V
Sorry, I can’t help you then (US).
There are several US dimmers rated for 600W Incadescent/Halogen loads - Leviton, Jasco, Inovelli, Lutron Caseta(not zigbee) that I know of, probably others.
Make sure you are looking at full specs, generally they are rated separately for LED vs Incadescent/Halogen. The above examples are 100w-150w for LEDs.
I would have thought at 220V ratings would actually be higher.
Hopefully someone else will come along.
