I would like to request some help of my project. I’ve also tried my GPT friend, but it was not able to solve my problem, I always get into a message loop.
I would like to control my light with PWM on GPIO4 (and parallely on GPIO14 as well). I have monostable switch on GPIO2.
Requirements would be:
-brightening/dimming from webgui manually and from HA manually+script. (as of now, it is working)
if Ha started the automatic dimming/brightening it should be overruled manually (it is also working)
for a short click it should toggle the light: turn on (100%) and turn off (0%) the light, it is not important what value was there before when it is different then 0%-> turn off. if it was 0% then it should changed to 100%.
for a long press it should increase the value (if it was 0%) OR previous action was dimming.
for a long press it should decrease the value (if it was different then 0%) AND previous action was brightening.
Unfortunately, I’ve encountered a problem where, after the lights are turned off and I attempt to brighten them, they start blinking or sometimes do not respond to the first few actions for several minutes after flashing and boots up correctly.
(I’ve tried to invert the code, then it never dimmed, and fully shined.)
- I bet the startup unressponsiveness is another issue, so first of all let’s focus to the actions.
Please let me know what I’ve missed!
light:
- platform: monochromatic
name: ${friendly_name} Indoor Lighting
output: ${IdPrefix}_light_indoor_out
default_transition_length: 1.0s
icon: "mdi:castle"
on_turn_off:
then:
- lambda: 'id(button_released_after_brightening) = false;'
- lambda: 'id(button_released_after_dimming) = true;'
on_turn_on:
then:
- lambda: 'id(button_released_after_brightening) = true;'
- lambda: 'id(button_released_after_dimming) = false;'
name: ${friendly_name} Outdoor Lighting
output: ${IdPrefix}_light_outdoor_out
icon: "mdi:chess-rook"
on_turn_off:
then:
on_turn_on:
then:
# Example output entry
output:
- platform: esp8266_pwm
pin: GPIO4
frequency: 200 Hz
#inverted: false
zero_means_zero: true
min_power: 0.00
max_power: 1.00
pin: GPIO14
frequency: 200 Hz
#inverted: false
min_power: 0.00
max_power: 1.00
- platform: gpio
pin: GPIO15
binary_sensor:
name: "Dimming in Progress"
lambda: |-
return id(dimming_in_progress);
name: "Manual control mode"
lambda: |-
return id(manual_control);
- platform: gpio
pin:
number: GPIO2
mode: INPUT_PULLUP
inverted: true
icon: "mdi:castle"
filters:
- delayed_on_off: 50ms
on_multi_click:
- timing:
- ON for at most 1s
- OFF for at least 0.5s
then:
- if:
condition:
and:
- lambda: 'return id(button_released_after_brightening);'
- or:
- light.is_on: ${IdPrefix}_light
- light.is_on: ${IdPrefix}_light_outdoor
then:
- light.turn_off:
transition_length: 2.5s
- light.turn_off:
else:
- light.turn_on:
brightness: 100%
- light.turn_on:
brightness: 100%
- timing:
- ON for at least 1s
then:
- while:
condition:
binary_sensor.is_on: ${IdPrefix}_light_touch
then:
- if:
condition:
and:
- or:
then:
- light.dim_relative:
relative_brightness: -4%
transition_length: 0.2s
else:
relative_brightness: 4%
- delay: 0.2s
on_release:
then:
- if:
condition:
lambda: 'return id(dimming_in_progress);'
then:
- lambda: 'id(manual_control) = true;'
on_press:
then:
globals:
- id: manual_control
type: bool
restore_value: no
initial_value: 'false'
- id: dimming_in_progress
type: bool
restore_value: no
- id: button_released_after_brightening
type: bool
restore_value: no
- id: button_released_after_dimming
type: bool
restore_value: no
Thank’s in advance!
