I am new to HA (installed it last week), this is my first post. I am using FHEM for 5 years, but I never liked the frontend options. So I am trying to mirror devices in HA via MQTT Bridge to make use of lovelace.
I started with 4 lamps in configuration.yaml that are enocean devices on the fhem side and now appear as light entities in HA. One of the enocean actors (lamp4) is a dimmer, the others are on/off.
When I create a vertical stack in lovelace, the on/off lights are looking different as the dimmable light, which has two “flash” icons. How do a get the dimmable lamp to look the same ?
Definition of the ligths:
light:
- platform: mqtt
optimistic: false
retain: false
command_topic: "fhem/lamp1/set"
state_topic: "fhem/lamp1/state"
payload_on: "B0"
payload_off: "BI"
- platform: mqtt
optimistic: false
retain: false
command_topic: "fhem/lamp2/set"
state_topic: "fhem/lamp2/state"
payload_on: "B0"
payload_off: "BI"
- platform: mqtt
optimistic: false
retain: false
command_topic: "fhem/lamp3/set"
state_topic: "fhem/lamp3/state"
payload_on: "B0"
payload_off: "BI"
- platform: mqtt
optimistic: true
retain: false
brightness_scale: 100
on_command_type: first
command_topic: "fhem/lamp4/set"
brightness_command_topic: "fhem/lamp4/setdim"
brightness_state_topic: "fhem/lamp4/dim"
state_topic: "fhem/lamp4/state"
payload_on: "on"
payload_off: "off"
This should be simple, but I have been trying to figure this out for several hours now. Any hint would be appreciated.
TIA, gadget
