I recently bought some Tradfri Leds that are able to dim and change white colors.
They are installed in the same lamp.
Now i try to find a way to simultaniously dim them and change the color.
Im new to HA so my knowledge is a bit limited.
What is the simplest way to do that?
I was able to switch them on or off with a script that contains them. But this was not possible for dimming or color change.
Thanks for your help!
If on Tradfri gateway - just create the light group (group ligts into single light entity that can be controlled as one).
If using other ZigBee solution (like Conbee stick + deconz) there should be light group automatically created within deconz to to the same. Again this will act as single light entity.
I use a cc2531 USB stick with ZigBee2MQTT. No Tradfri Gateway.
So i have to use the internal functions of HA.
Another option is to add a line at the end into configuration.yaml:
group: !include groups.yaml
And then add the file groups.yaml at the same level as the file automation.yaml, with content like:
living_room_lights:
entities:
- light.computer_1
- light.computer_2
- light.computer_3
- light.staande_lamp_1
- light.staande_lamp_2
- switch.staande_lamp_3
kitchen_lights:
entities:
- light.keuken_1
- light.keuken_2
- light.keuken_3
With this method you can combine e.g. lights with switches.
Thanks a lot.
Will try that out today.
Zigbee2mqtt has support for Zigbee groups. By using Zigbee groups you can control multiple devices simultaneously with one command.
Works! Thanks a lot!
But another question on this topic.
Is it possible to use these Lovelace buttons for the group too?
Did you create a HA group, a HA light group or a zigbee2mqtt group ?
I used a HA light group in the groups.yaml.
I think for that to work you will need to create a light-group in configuration.yaml.
Now you have created an entity that starts with group.something
When you create a light-group, I would assume it starts with light.group_something_...
which you can enter as entry on a lovelace card.
But, maybe the lovelace card can accept a group.something
as entry? Just try it.
Works now. Thanks a lot for Your help guys.
I did everything right, with your advices.
But strange enough, the light group was not displayed until i restarted HA.
That’s normal, any changes you make to an existing file will only become active after a restart of HA Core.
Didnt know that. But thanks again.
Okay guys, another question.
Now i try to add a second light group.
But the syntax drives me crazy. I tried this in the configuration.yaml, and i get an error “duplicated mappy key…”
# Gruppe Wohnzimmerlampe
light:
- platform: group
entities:
- light.0x680ae2fffe6e885e_light
- light.0x680ae2fffe6e8681_light
# Gruppe Schlafzimmerlampe 1
light:
- platform: group
entities:
- light.schlafzimmerlampe_led1_light
- light.schlafzimmerlampe_led2_light
The error points to the second “light” entry.
Please format your code correct.
https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/114371/4
Especially point 11
Sorry, corrected.
The first group works. But not the second.
I think you need to remove the second
light:
Thanks again Francis. That was the solution.
