I want to use ESP8266 or ESP32 to dim these non-addressable 12V led lights. can I do it with WLED or ESPhome?
You can do it with either of them.
My only experience with WLED is a 30 led WS2818B 5V strip running directly off the ESP8266 chip.
what components do I need to setup?
I think you’ll need to do some soldering, since the ESP8266 IO pins cannot deliver the power necessary to drive your LED string.
For my RGB LED strips I do something like this on each channel. The single LED represents the whole string of LEDs. There’s a current limiting resistor to prevent a current surge while switching the MOSFET, and a pull-down resistor to hold the gate low unless you drive it high with the ESP8266.
I do have an ESP32 running Esphome to connect the Xiamoi Bluetooth thermometer to the home assistant.
Can you post actual images of the device?
I googled around and found this video
which of these ESP32 board I should buy
or WROOM ESP32 Wifi Based Microcontroller Development Board Nodemcu
and this 15A 400W D4184 MOSFET Trigger Switch Drive Module In Pakistan will work or not?
The 4-pin socket header is for testing with a single RGB LED that can be driven by the ESP8266; the LED strings are driven via the screw terminals.
I am stuck here
Clicking on adopt doesn’t do anything. I can access the esp32 on its page 192.xx.xx.xx
edited the code but when I tried to install it wirelessly
got this error
INFO Reading configuration /config/esphome/esp-web-tools-example-11db18.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing esp-web-tools-esp32-e94da0 (board: esp32dev; framework: arduino; platform: espressif32 @ 3.3.2)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
warning: Calling missing SConscript without error is deprecated.
Transition by adding must_exist=False to SConscript calls.
Missing SConscript '/data/cache/platformio/packages/framework-arduinoespressif32/tools/platformio-build.py'
File "/data/cache/platformio/platforms/espressif32/builder/frameworks/arduino.py", line 41, in <module>
Library Manager: Installing FS
Warning! Could not find the package with 'FS' requirements for your system 'linux_armv7l'
Library Manager: Installing Update
Warning! Could not find the package with 'Update' requirements for your system 'linux_armv7l'
Library Manager: Installing ESPmDNS
Warning! Could not find the package with 'ESPmDNS' requirements for your system 'linux_armv7l'
Dependency Graph
|-- <AsyncTCP-esphome> 1.2.2
|-- <WiFi> 1.2.7
|-- <ESPAsyncWebServer-esphome> 2.0.0
|-- <DNSServer> 1.1.0
Compiling /data/esp-web-tools-esp32-e94da0/.pioenvs/esp-web-tools-esp32-e94da0/src/esphome/components/api/api_connection.cpp.o
Compiling /data/esp-web-tools-esp32-e94da0/.pioenvs/esp-web-tools-esp32-e94da0/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/esp-web-tools-esp32-e94da0/.pioenvs/esp-web-tools-esp32-e94da0/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/esp-web-tools-esp32-e94da0/.pioenvs/esp-web-tools-esp32-e94da0/src/esphome/components/api/api_pb2_service.cpp.o
In file included from /data/cache/platformio/packages/toolchain-xtensa32/xtensa-esp32-elf/include/c++/5.2.0/cstdint:35:0,
from src/esphome/components/api/api_frame_helper.h:2,
from src/esphome/components/api/api_frame_helper.cpp:1:
/data/cache/platformio/packages/toolchain-xtensa32/xtensa-esp32-elf/include/c++/5.2.0/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
#error This file requires compiler and library support for the \
from src/esphome/core/preferences.h:4,
from src/esphome/core/application.h:6,
from src/esphome/components/api/api_connection.h:4,
from src/esphome/components/api/api_connection.cpp:1:
In file included from src/esphome/components/api/proto.h:4:0,
from src/esphome/components/api/api_pb2.h:5,
from src/esphome/components/api/api_pb2.cpp:3:
src/esphome/core/log.h:15:21: fatal error: esp_err.h: No such file or directory
* Looking for esp_err.h dependency? Check our library registry!
* CLI > platformio lib search "header:esp_err.h"
* Web > https://platformio.org/lib/search?query=header:esp_err.h
compilation terminated.
In file included from src/esphome/core/application.h:8:0,
src/esphome/core/helpers.h:10:29: fatal error: esp32-hal-psram.h: No such file or directory
* Looking for esp32-hal-psram.h dependency? Check our library registry!
* CLI > platformio lib search "header:esp32-hal-psram.h"
* Web > https://platformio.org/lib/search?query=header:esp32-hal-psram.h
*** [/data/esp-web-tools-esp32-e94da0/.pioenvs/esp-web-tools-esp32-e94da0/src/esphome/components/api/api_pb2.cpp.o] Error 1
*** [/data/esp-web-tools-esp32-e94da0/.pioenvs/esp-web-tools-esp32-e94da0/src/esphome/components/api/api_connection.cpp.o] Error 1
from src/esphome/components/api/api_pb2_service.h:5,
from src/esphome/components/api/api_pb2_service.cpp:3:
*** [/data/esp-web-tools-esp32-e94da0/.pioenvs/esp-web-tools-esp32-e94da0/src/esphome/components/api/api_pb2_service.cpp.o] Error 1
In file included from src/esphome/components/socket/socket.h:5:0,
from src/esphome/components/api/api_frame_helper.h:13,
src/esphome/components/socket/headers.h:116:23: fatal error: sys/ioctl.h: No such file or directory
*** [/data/esp-web-tools-esp32-e94da0/.pioenvs/esp-web-tools-esp32-e94da0/src/esphome/components/api/api_frame_helper.cpp.o] Error 1
========================= [FAILED] Took 33.25 seconds =========================
Progress so far,
LED does turn on, if I connect the D19 pin on ESP32 to PWM/trigger pin on power mosfet. It doesn’t matter which firmware I have on esp32, tried to flash esphome onto esp32 and ended up with above error (previous post) and then I flashed wled which was flashed without any issue, but I can’t change the brightness from wled app/ web-interface.
this is driving me crazy.
no replies?
I think you also need to connect the ground wire to the mosfet board.
When I connect to ground(esp32) to ground(mosfet board), the LED turns off. it isn’t being controlled by a WLED brightness slider.
I am unable to properly install esphome on ESP32, it gets installed through esp webtool but when I try to upload any sketch the following error happens
Dependency Graph
|-- <WiFi> 1.2.7
here is the log from esp2 device page
After doing it with WLED, I have installed esphome on the second esp32 with the following code which includes other sensors too.
esphome:
platform: ESP32
board: esp32dev
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "xxxxxxxxxxxxxxxxxxxxxxx"
esp32_ble_tracker:
wifi:
ssid: "ABC"
password: "xxxxxxxxxxxxxxxxx"
ap:
ssid: "Esp-Br-Node Fallback Hotspot"
password: "xxxxxxxxxxxxxxxx"
captive_portal:
- platform: xiaomi_lywsd03mmc
mac_address: "xx:xx:xx:xx:xx"
bindkey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
temperature:
name: "Room Temperature"
humidity:
name: "room Humidity"
battery_level:
name: "room Battery Level"
- platform: esp32_hall
name: "ESP32 Hall Sensor"
update_interval: 5s
# Example configuration entry
light:
- platform: status_led
pin: GPIO2
Now I want to do what I did with wled,
- Turn on the light at sunrise
- Increase brightness gradually until midday
- Decrease brightness gradually until sunset
- Turn off the light at Sunset.
How should I do it?
Edit:
What should mention in brightness
I went through light integration but it I am more confused. Light - Home Assistant
To set this up with ESPhome…you need to set an output in the config along with the monochromatic setting:
esphome:
friendly_name: Dim LED TEst
esp32:
board: esp32-c3-devkitm-1
# Enable logging
logger:
api:
ota:
- platform: esphome
wifi:
ssid: !secret wifi_ssid
output:
- platform: ledc
pin: 03
light:
- platform: monochromatic
output: out_1
