Hi There,
another project to share
I have managed to use NWPM module (https://dimplex.atlassian.net/wiki/spaces/DW/pages/2862383109/NWPM#Beschreibung-und-Download-PlugIn) with WPM 2006 Plus controller to control my Dimplex LS 8 AS Heat Pump throught MODBUS protocol.
You have to configure your NWPM plugin module to use ModBus TCP:
- login to pcoWEB โ preferences โ network โ firmware โ opens new dialog window
- switch to ModBus TCP tab at new opened window and enable: ModBus TCP Status โ Enable, ModBus TCP Port โ 502 (I have used 1.5.x Map mode)
- Submit
Create modbus.yaml:
- name: dimplex
type: tcp
host: 192.168.1.xx ##Your NWPM module IP address here
port: 502
delay: 5
timeout: 5
sensors: ## Ordered by modbus address
- name: Dimplex Mode
slave: 1
address: 5007
scan_interval: 5
input_type: input
- name: Dimplex Smart Grid
slave: 1
address: 5167
scan_interval: 5
input_type: input
- name: Dimplex Parallel Displacement
slave: 1
address: 5002
scan_interval: 5
input_type: input
modify configuration.yaml to include modbus.yaml and create Heating mode selection list:
modbus: !include modbus.yaml
input_select:
heatpump_mode:
options:
- "Summer"
- "Auto"
- "Holiday"
- "Party"
- "Heat gen 2"
icon: mdi:home-thermometer
Modify your automations.yaml to simplify Dimplex Modbus registry settings for heating modes:
- id: '1713981187327'
alias: set_heatpump_mode
description: Nastav mod TC Dimplex
- platform: state
entity_id:
- input_select.heatpump_mode
condition: []
- service: modbus.write_register
address: 5007
hub: dimplex
slave: 1
value: '{{ state_attr(trigger.entity_id,''options'').index(states(trigger.entity_id))
- id: '1714546261857'
alias: act_heatpump_mode
description: refresh heatpump mode input_select
- platform: state
entity_id:
- sensor.dimplex_mode
condition: []
- service: input_select.select_option
entity_id: input_select.heatpump_mode
option: '{{ state_attr(''input_select.heatpump_mode'',''options'') [states(trigger.entity_id) | int] }}'
mode: single
To reach other setings / registers, just follow this dimplex wiki guide:
https://dimplex.atlassian.net/wiki/spaces/DW/pages/3021504513/Modbus+TCP+Anbindung
