Dingz Dimmer and LED ... how to configure them
Now, my Dingz Dimmer and LED Configuration has a state, I can share it with you.
Suggestions for improvement are welcome.
rest_commands
  dingz_generic_dimmer:
    url: http://{{ ip }}/api/v1/dimmer/{{ dimmer }}/{{ enum }}
    method: POST
    payload: 'value={{ value }}'
    content_type: 'application/x-www-form-urlencoded; charset=utf-8'
  dingz_generic_led_onoff:
    url: http://{{ ip }}/api/v1/led/set
    method: POST
    payload: 'action={{ action }}'
  dingz_generic_led:
    method: POST
    payload: 'action={{ action }}&color={{ colh }};{{ cols }};{{ colv }}&mode=hsv'
scripts
dingz_led_level_generic_onoff:
  alias: Dingz LED Level Generic onoff
  sequence:
  - service: rest_command.dingz_generic_led_onoff
      action: '{{ action }}'
      ip: '{{ ip }}'
  - service: homeassistant.update_entity
      entity_id: '{{ force_entity }}'
  mode: single
  icon: hass:lightbulb
dingz_led_level_generic:
  sequence:
      colh: '{{ colh }}'
      cols: '{{ cols }}'
      colv: '{{ colv }}'
      ip: '{{ ip }}'
  mode: single
dingz_light_level_generic:
  alias: Dingz Light Level Generic
  sequence:
  - service: rest_command.dingz_generic_dimmer
      dimmer: '{{ dimmer }}'
      enum: '{{ enum }}'
      value: '{{ brightness }}'
      ip: '{{ ip }}'
  mode: single
light template
    # ####### Dingz Dusche Decke Light
      dingz_dusche_decke_light:
        unique_id: dingz_dusche_decke_light
        friendly_name: "Dingz Dusche Decke"
        level_template: "{{ (state_attr('sensor.dingz_dusche_state', 'dimmers')[2]['output']*255/100)|int }}"
        value_template: "{{ state_attr('sensor.dingz_dusche_state', 'dimmers')[2]['on']}}"
        turn_on:
          service: script.dingz_light_level_generic
          entity_id: light.dingz_dusche_decke_light
            brightness: "40"
            enum: "on"
            dimmer: 2
            ip: !secret ip_dingz_dusche
            force_entity: sensor.dingz_dusche_state
        turn_off:
            brightness: "0"
            enum: "off"
            dimmer: 2
        set_level:
            brightness: "{{ (brightness * 100 / 255) | int }}"
            enum: "on"
            dimmer: 2
    # ####### Dingz Markise1 LED
      dingz_markise1_led:
        unique_id: dingz_markise1_led
        friendly_name: "Dingz Markise1 LED"
        level_template: "{{ ((state_attr('sensor.dingz_markise1_state', 'led')['hsv'].split(';')[2]|int) * 255 / 100) | int }}"
        value_template: "{{ state_attr('sensor.dingz_markise1_state', 'led')['on'] }}"
        color_template: "({{ state_attr('sensor.dingz_markise1_state', 'led')['hsv'].split(';')[0] | int }}, {{ state_attr('sensor.dingz_markise1_state', 'led')['hsv'].split(';')[1] | int }})"
        turn_on:
          service: script.dingz_led_level_generic_onoff
          entity_id: led.dingz_markise1_led
            action: "on"
            ip: !secret ip_dingz_markise1
            force_entity: sensor.dingz_markise1_state
        turn_off:
            action: "off"
        set_level:
            action: "on"
            colh: "{{ state_attr('sensor.dingz_markise1_state', 'led')['hsv'].split(';')[0] | int }}"
            cols: "{{ state_attr('sensor.dingz_markise1_state', 'led')['hsv'].split(';')[1] | int }}"
            colv: "{{ (brightness * 100 / 255) | int }}"
        set_color:
            action: "on"
            colh: "{{ h }}"
            cols: "{{ s }}"
            colv: "{{ state_attr('sensor.dingz_markise1_state', 'led')['hsv'].split(';')[2] }}"
and finally, the depending sensor example, that gets information from dingz
platform: rest
method: GET
resource: !secret url_sensor_dingz_kuche
# http://ip/api/v1/state
name: Dingz Kuche State
value_template: "OK"
json_attributes:
  - "dimmers"
  - "blinds"
  - "led"
  - "sensors"
  - "thermostat"
  - "wifi"
