DirecTV configuration problem
Solved: External device - > current channel = allow in settings/whole Home
UPDATE: This is listed in the HA issue tracker on GitHub as a problem with tthe DirectPy.py file that needs to be updated. How is this done in Hass.io? Thanks.
------------------- (original post)
Thanks for any help on this issue. I am unable to get my DirecTV receiver to show up in Hass.io. Here is the error log:
2017-09-14 10:04:08 ERROR (MainThread) [homeassistant.components.media_player] Error while setting up platform directv
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py”, line 164, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File “/usr/lib/python3.6/asyncio/tasks.py”, line 352, in wait_for
return fut.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 244, in result
raise self._exception
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 55, in run
File “/usr/lib/python3.6/site-packages/homeassistant/components/media_player/directv.py”, line 75, in setup_platform
dtvs.append(DirecTvDevice(*host))
File “/usr/lib/python3.6/site-packages/homeassistant/components/media_player/directv.py”, line 90, in init
self.dtv = DIRECTV(host, port, device)
File “/usr/lib/python3.6/site-packages/DirectPy.py”, line 33, in init
self.get_tuned()
File “/usr/lib/python3.6/site-packages/DirectPy.py”, line 73, in get_tuned
self.channel = self._combine_channel(jResp[‘major’],jResp[‘minor’])
KeyError: ‘major’
2017-09-14 10:04:33 WARNING (SyncWorker_1) [netdisco.ssdp] Error fetching description at 192.168.2.35
2017-09-14 10:04:38 WARNING (SyncWorker_1) [netdisco.ssdp] Error fetching description at http://192.168.1.4:49152/wps_device.xml
2017-09-14 10:31:51 WARNING (SyncWorker_0) [netdisco.ssdp] Error fetching description at http://169.254.6.10:63444/upnp/xml/devices/MediaRenderer1.xml
This is the relevant portion of my configuration.yaml file:
  • platform: directv
    host: 192.168.2.64
    port: 8080
    device: 0
I tried leaving the autodiscovery on first, then ignored the directv component and specified as above. It is an HR54 Genie. I’m running .53. Thanks again.
Did you ever figure this out I’m having the same issue
Yes, you must go to settings on your main Genie, select whole home menu, external device menu and make sure external access, current program and recording are set to allow.
That worked!! I still see the errors in the log but it sees all my genies and everything. Thank you!
Fixed the problem with my dinosaur HR21s too. Thx for posting.
