Disable a Trigger
If you need to make a value in a trigger optional in your automation, there is a way.
Full instructions:
This is handy in places where you you want to make sure a trigger is valid before you use it. Be careful, however. If your only triggers are all disabled, the automation no longer has a way to trigger.
Remember the code in the template brackets needs to follow the limited template rules because it needs to be available at the time of trigger.
Here is a sample where you are checking if an optional blueprint !input is populated or not. There are other examples in the Docs.
input:
  occupancy:
  illuminance:
  threshold_entity:
  threshold_fixed:
trigger_variables:
  occupancy_var: !input occupancy
  - type: state
    entity_id: !input occupancy
    enabled: "{{ occupancy_var is not none }}"
    to: "off
