Disable Auth for whole internet
Hello. I need to do opened dashboard based HA. So i need bypass logins for any users in any networks except home network 192.168.1.1/24
In the internet I can find number of quastions how to realise same idea but could not find any answers. If I’m googling bad, ples send me links with implementations of free access without entering login\password for any ip adresses except home network.
Could such auth_provider work for me?
homeassistant:
  auth_providers:
    - type: trusted_networks
      trusted_networks:
		# ! chose maximum networks EXCLUDING 192.168.x.x  !
		# using any ip calculator
		- 0.0.0.0/1
		- 128.0.0.0/2
		- 192.0.0.0/9
		- 192.170.0.0/15
		- 192.176.0.0/12
		- 192.192.0.0/10
		- 193.0.0.0/8
		- 194.0.0.0/7
		- 196.0.0.0/6
		- 200.0.0.0/5
		- 208.0.0.0/4
		- 224.0.0.0/3
        - 0000::/0
      allow_bypass_login: true
    - type: homeassistant
In this case mostly all networks probably shoud be avaliable for bypassing, except 192.168.x.x (and maybe some others subnets close to this range)
If it can work in teory, let me know what I need to change in order to give the life such configuration.
is any advises how to switch off authorisation for whole internet? )
any help, guys?
Guys need suggestions, how to open app for anybody?
up anyhrlp
Hey mates, strongly need your support
What have you tried, what does work and what not? When looking at the documentation it seems your config is correct.
Maybe you can search how the ‘Demo’ Home Assistant project is made available without auth. (Demo - Home Assistant)
