Disable bluetooth in configuration.yaml
is there a way to disable bluetooth in homeassistant (via a configuration.yaml entry).
I have found the various subjects about disabling it on a raspberry pi, which is not what I’m using.
I’m running HA core in a proxmox VM which does not have any bluetooth, nor WIFI, only a zigbee dongle passed through.
I’m seeing a warning message at each HA (re-)start, telling me:
Setup of bluetooth is taking over 10 seconds.
I know this is harmless, because apart from that message, it’s working nicely. But I’m still willing to disable this probing if it’s possible to do so.
Is there a comprehensive documentation about what can be in the YAML config file ?
I’ve read Configuration.yaml - Home Assistant but did not find anything like that in it.
You would have to remove default_config and enumerate the integrations manually (without bluetooth:, of course)
Default Config - Home Assistant (home-assistant.io)
Thanks a lot, that was the thing I missed.
Are all the integrations coming from default_config: come with only their default config / values, or is there some different config coming with it ?
I.e. can I just replace default_config: by the list of the integrations it contains and get the same thing ?
Yes, you can
Perfect then !
