2andr
(Sandr)
1
Please help. I have connected 6pcs CCT dimmers Sunricher zv9101fa CCT Via OpenZwave integration.
How can i disable, in lovelace, RGB color wheel for CCT dimmer?
I need only CCT line because this dimmer have only two channel:
and no RGB channels!
Hw can i do this?
Syntox
2
If you’re using HACS there is a card with more options (including this one):
Otherwise you could create an input_number and assign its value to the light
firstof9
(firstof9)
3
Can you do a mqtt.dump
of that node?
If your device is reporting it can do RGB color channels that’s why it’s giving you the color wheel.
