I have an automation that sets my theromostat target temperature according to a schedule, as per below (I have not used
the schedule helper, but written the schedule in schedule.yaml)
thermostat_schedule_livingroom:
name: "Thermostat schedule livingroom"
monday:
to: "21:00:00"
tuesday:
to: "21:00:00"
wednesday:
to: "21:00:00"
thursday:
to: "21:00:00"
friday:
to: "21:00:00"
saturday:
to: "21:00:00"
sunday:
to: "21:00:00"
I would like to add a “boost” automation that increases the target temperature for a user-specified time regardless of the schedule, and then returns the temperature to what it should be, given the time of day (7
when the schedule is off
and states('input_number.schedule_target_temp_livingroom')
when the schedule is on
alias: boost_livingroom
description: Boost living room heat for specified time
- platform: state
entity_id:
- input_button.boost_livingroom
condition: []
- service: climate.set_temperature
entity_id: climate.lumi_lumi_airrtc_agl001_thermostat_2
temperature: 24
hvac_mode: heat
enabled: true
- delay: "{{(states('input_number.boost_time_livingroom')|int) * 3600}}"
- if:
- condition: state
entity_id: schedule.thermostat_schedule_livingroom
state: "on"
then:
temperature: "{{states('input_number.schedule_target_temp_livingroom')}}"
hvac_mode: heat
else:
temperature: 7
hvac_mode: heat
mode: single
This works fine, as long as the schedule doesn’t switch state during the delay period. If it does, the thermostat changes to the schedule-controlled defaults instead of completing the boost-delay period.
I thought that the simplest approach would be to disable the schedule while the boost automation is activated. Is there a way to disable/enable the schedule within the boost automation actions?
I have seen this post about schedule helper Ability to override Schedule Helpers, but it does not seem to have had responses.
Also Universal Override Timer - #8 by 123
